Old 02-21-2005, 03:10 PM   #2041
BSchorr's Avatar
Trader Rating: 92 (100%+)
Send a message via AIM to BSchorr Send a message via Yahoo to BSchorr Send a message via Skype™ to BSchorr
Hey, my spur gear is a 75 tooth! so what pinion with a p2k2, and then what pinion with a monster stock?
Proline ~ Genesis R/C Products ~ First Premier Satellites
BSchorr is offline   Reply With Quote
Old 02-21-2005, 06:37 PM   #2042
lee
BSchorr
The last time I was up there (the Rumble) I was running 102/34 in my tc3 with a monster. With 48 pitch I would start with a 75/25 maybe even a 24 tooth pinion with a monster and those tires in the photo. Go up 2 to 3 teeth for a p2k2.
lee is offline   Reply With Quote
Old 02-21-2005, 06:50 PM   #2043
BSchorr's Avatar
Originally posted by lee
BSchorr
Hey, is this Homer Lee? ok, i have a 24 on it right now, i am running alittle slower then the pack, just by a hair, so like a 25,26 then?
Old 02-21-2005, 06:51 PM   #2044
Send a message via AIM to greencactus3
Originally posted by Lost Aggresiva
Don't hold me to it, but I believe that every 0.010" off the comm is supposed to be like advancing the timing by a degree or so. Or something to that extent.
i think thats only for the mabuchi540 motors. silver can ones. regular motors will lose torque with smaller comms but will gain rpms. slightly for both
greencactus3 is offline   Reply With Quote
Old 02-21-2005, 06:56 PM   #2045
Twin-Kyle's Avatar
Originally posted by micros_rock
3 comm segments are in contact with the brushes 100% of the time. You get more power, but lose efficiency because the comm shorts out a fraction of the time.
This is called arc.Very bad thing for motors.You want to try to stop as much arc as you can.
Twin-Kyle is offline   Reply With Quote
Old 02-22-2005, 07:25 PM   #2046
lee
BSchorr
Yeah this is Homer just keep going up a tooth until your lap times start to fall off.
Old 03-02-2005, 11:31 AM   #2047
jhigga15's Avatar
Team Orion Core Stock RS 27T Rebuild Dyn Motor
SPECS: Battery Simulation at 7.2V
RPM: 25.678
Power Max: 105.7 W
Power Avg: 66.2 W
Efficiency Max: 58.7%
Efficiency Avg: 37.7%
That engine seems to be good...is it?
jhigga15 is offline   Reply With Quote
Old 03-02-2005, 01:39 PM   #2048
Qwiglee's Avatar
Do you know what the amp draw is at certain input voltages like 5 volts? That is how I compare mine on the dyno. Im not sure about watts that must be off the manufacturer's label.
Also, just want to politely point out that they are called "motors" not "engines" ...electric cars have "motors" and nitro cars have "engines."
Brian Aldridge
Qwiglee is offline   Reply With Quote
Old 03-03-2005, 09:29 AM   #2049
jhigga15's Avatar
My Bad...Is that why when I put gas in my electric motor it starts a fire?
Old 03-07-2005, 05:57 PM   #2050
I just built a P2K2 with F brush's and used it on a small carpet track; it just plain rips. I was able to gear it 7 teeth higher than a monster; it has more bottom and top end. In fact it had so much more bottom end that I needed to change my sedan's setup to compensate for the insane weight transfer. I compared the P2K2 back to back with a monster; hands down the P2K2 out powered it. Now I need to try this motor on a off road track.
kmorast is offline   Reply With Quote
Old 03-07-2005, 06:25 PM   #2051
imjonah's Avatar
Default 4 mag Epic 'stock" motor
What is the current wisdom about the
Epic Binary 2 outlaw stock motor.
It does not seem like it is likely to be ROAR legal. It appears most people still prefer the Monster.
I have 3 of them and they seem to be noticebly better on the big fast tracks I like to run on than any of my other motors.
imjonah is offline   Reply With Quote
Old 03-07-2005, 06:55 PM   #2052
Send a message via AIM to micros_rock
Default Re: 4 mag Epic 'stock" motor
You have to gear these motor right, then they are screaming. Also, what size is your track? Try starting with purples on both sides and 767's. Gear 2 teeth lower than a monster ~ 7.16
micros_rock is offline   Reply With Quote
Old 03-07-2005, 11:50 PM   #2053
Default Re: Re: 4 mag Epic 'stock" motor
Francis,
You have pm.
thanks
manokgt4 is offline   Reply With Quote
Old 03-08-2005, 05:35 AM   #2054
crACkeD ChaSsiS's Avatar
Send a message via AIM to crACkeD ChaSsiS Send a message via Yahoo to crACkeD ChaSsiS
Default brushes
kmorast-were did u get the F-brushes from? and wat springs were u running and on wat side did u run them on>?
crACkeD ChaSsiS is offline   Reply With Quote
Old 03-08-2005, 05:48 AM   #2055
fire929's Avatar
Default P2k2
Originally posted by OVA
Hi Jesse
what do you want to lnow? Well the PK2 is a torque motor and you have to gears up 4 teeth in 64th pitch compare the MS. the PK2 it is the best stock motor in the history and the PK2 last longer and you get yout money worth...MS it is better for out door racing larger trtack..... lately the F brushes seem to works very well for the munster stock ....
When you sya gear up are you switching to a pinion 4 teeth bigger then you would use on a monster. Have you found that the purples are to heavy for the f-brushes.
Trex 450
Trex 600
EFL Heli's
Futaba 8fg
Align 3gx
fire929 is offline   Reply With Quote
19T Motor Forum Korey Harbke Electric On-Road 550 04-11-2009 08:27 AM
Stock motor sale !!!!CO27,P2k Pro, Monsters stock Marcos.J R/C Items: For Sale/Trade 36 06-27-2006 06:26 AM
Mod Motor forum Taz_S Electric On-Road 58 11-28-2003 12:58 AM
Stock Motor Forum JLMG1971 Electric On-Road 2 10-22-2002 03:07 AM
Stock Motor forum Taz_S Electric On-Road 62 09-14-2001 12:32 PM
