Old 01-25-2005, 11:14 PM   #1966
Still Bill's Avatar
Originally posted by James Nguyen
You guys believe too much in the numbers. Numbers can all vary from dyno to dyno and calibration. I buy motors that I can't even look at the numbers and run them out of the package. I ran an out of the package motor at the last big race. It had 59 watts on the sticker. Stickers are nothing on the track. Just make sure everything is running smooth and aligned. You can give me or Aaron any stock motor you have and we will make it fast.
American (r/c) idols you both are...I should start pitting next to you guys...
And...if I could carry the speed you two have through the corners, I wouldn't be bothering much about my motors.
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
And a pair of Associated B6 buggies for turf and clay tracks.
Still Bill is offline   Reply With Quote
Old 01-25-2005, 11:16 PM   #1967
Or you could just come up to us and ask us for help. We don't bite. I am always willing to give out the setup I am running on my car. If I am at the track I will always help anyone dial their cars in, but you have to come up to me as I don't really watch people practice too much.
James Nguyen is offline   Reply With Quote
Old 01-25-2005, 11:48 PM   #1968
Still Bill's Avatar
You know...I've always had this fear of pink...
Old 01-25-2005, 11:53 PM   #1969
tboned_2002's Avatar
James you racing down here this weekend? I want you to make me fast!
tboned_2002 is offline   Reply With Quote
Old 01-25-2005, 11:53 PM   #1970
Then I guess you won't be racing for a while then
Old 01-25-2005, 11:54 PM   #1971
I'm gonna try to get the day off by switching shifts with someone but I'm not sure if that's gonna happen.
Old 01-26-2005, 12:38 AM   #1972
Trader Rating: 15 (100%+)
Default binary
mccbri, small tracks run a purple positve and red negative..on large run red /green combo ....serrations are always better..run 767's or aggresive tech brushes..
AARON YOUNG is offline   Reply With Quote
Old 01-26-2005, 12:44 AM   #1973
Default watts?
you guys say 63 was good ?thats average the best were 67 to 69..should of bought all the ones i sold for 10 bucks..
Old 01-26-2005, 05:38 AM   #1974
Essnowyt's Avatar
Send a message via AIM to Essnowyt
Hello there motor guys. I race stock rubber touring cars with Monster HP motors. What have you guys found to be the best spring combo for 767's and a small track? Thanks for all your help.
Snowy.
Team XRay, RCAmerica, Motiv, Gravity RC, Schacht Design Works.
Drive it, Dont slide it!
Essnowyt is offline   Reply With Quote
Old 01-26-2005, 06:54 AM   #1975
Fuzzy's Avatar
Originally posted by out_to_lunch
Any thoughts on spring combinations for carpet 1/12th scale stock 4 cell? Would that purple spring be too much for this class?
Thanks,
Joe
lunch,
For 1/12 scale, try green springs all around. Because of the lower voltage and amperage in 1/12 scale, purple and red springs are simply not needed. The reason for going to heavier springs is to stop the brush from being blown off the comm by the arcing that occurs. The only thing that heavier springs do for 1/12 scale is increase the drag on the comm. I have experimented with a blue spring on the negative but didn't have much success. Hope this answers your question.
Fuzzy is offline   Reply With Quote
Old 01-26-2005, 10:53 AM   #1976
I'm confused. Is it good to have a high motor amp draw or not? My motor only pulls about 7/7.5 amps and an experienced racing friend of mine says his motors draw 9/9.5 amps which he says is better. However, some of the posts in this thread suggest that a high amp draw is bad.
Is a monster or P2K2 better on a tight indoor track?
ralph_c is offline   Reply With Quote
Old 01-26-2005, 12:20 PM   #1977
essnowyt the red/green combo is the best all around for the 767.
ralph c ...amp draw is good if their is nothing wrong with the motor ...but an oversprung motor or a bushing binding or shimmed to tight can cause high amp draw..
Old 01-26-2005, 12:24 PM   #1978
Fuzzy's Avatar
Ralph,
First, lets answer your second question. It's been a long time since I have run a P2K2. From what i've seen, they produce more torque than a monster. So it might be a better motor for touring car. But if your running a 1/12 scale, that much torque is not needed to move something so small and light. Go with the monster. Maybe. Here's something i've read in Big Jim's Motor Black book that has helped me when tuning motors or buying new motors. "Always go with the motor that produces the highest power number. You can always compensate for the lack of rpm or torque with the proper gear ratio." Here's why. Power (watts) = rpm x torque. It doesn't matter if the motor has a little less rpm as long as the amount of torque makes up for it. The reverse is true for torque. If the motor is down on torque, such as the new Epic ROAR stocks, the rpms should be high enough to bring the power number up when multiplied times the torque figure. Does this answer your question about the monster vs. P2K2?
As for the issue of how many amps the motor pulls. Generally speaking, the higher the amps, the more power it makes. This idea is fine for touring car, where the cars are heavier and making run time in a race doesn't really come into play. For 1/12 scale, run time definitely matters. I run 1/12 scale, so my good motors usually pull between 9-9.5 amps during break-in. If your motors are pulling 7-7.5 amps, they may need to be rebuilt or you may need a new one all together.
Hope I helped some.
Old 01-26-2005, 12:37 PM   #1979
I assume you guys are talking @ 5 volts for the above amp readings, please correct me if I am wrong
Jim D.
ukeejim is offline   Reply With Quote
Old 01-26-2005, 02:30 PM   #1980
I got my amp rating at 3v I think on my friends turbo CFX during break in. I've just skimmed it and put in new brushes (4499's) so maybe the motor needs replacing. Still keeps up with the others well enough though. (need to improve driving before it will win me races anyway)
I've always run a monster up till now, but I was just looking on the Trinity site where it says the P2K2 is more torgue based so just wondered.
Thanks for the help.
19T Motor Forum Korey Harbke Electric On-Road 550 04-11-2009 08:27 AM
Stock motor sale !!!!CO27,P2k Pro, Monsters stock Marcos.J R/C Items: For Sale/Trade 36 06-27-2006 06:26 AM
Mod Motor forum Taz_S Electric On-Road 58 11-28-2003 12:58 AM
Stock Motor Forum JLMG1971 Electric On-Road 2 10-22-2002 03:07 AM
Stock Motor forum Taz_S Electric On-Road 62 09-14-2001 12:32 PM
