Old 08-18-2004, 09:30 PM   #1861
etzkev's Avatar
Send a message via AIM to etzkev
Originally posted by Slider
etzkev I gotta agree with you on all the points you made except one.
I run monsters in stock with putnam brushes (green blue combo) with purple/ red springs, and I get ridiculous life out of them. The only putnam brush I've ever burnt was when a bearing collapsed in my TC3. Usually i replace the putnams when they get so short that I think they are significantly affecting the spring tension or starting to cock in the brush hoods.
I don't use any com drops, and simply clean the com with a com stick lightly between races. I usually only cut them every 8 - 10 runs as they don't seem to lose any significant power untill at least 10 runs. i have reserrated them before but I'm not convinced this is necessary if they are already well seated to the com.
As for how fast they are, I'm no A main driver but I'm very rarely outdone for motor speed anywhere on the track. And I often tune motors for a couple of friends who are A main drivers at a National Level here in Australia.
I recommend the green blue Putnam combo for all the stock racers at my local club. I just make sure they use relatively heavy springs (red/red minimum) and don't use straight greens.
i don't know how this translates to other stock motor though as I've been using Monsters pretty much exclusively of late. I am going to start playing with an MVP in the next couple of weeks though, it will be interesting to see how it compares.
That's great input. But, I don't understand how you were disagreeing with me? Haha, I really don't have much experience with Putnams, and didn't say anything about them. I think that was TexRacer. I'll eventually try some Putnams because I know they are fast and I got a few friends who run for Putnam Propulsion...so maybe they will let me try some out.
-Kevin
etzkev is offline   Reply With Quote
Old 08-18-2004, 10:35 PM   #1862
nick51's Avatar
Send a message via AIM to nick51
who are putnam brushes by and where could i find some
nick51 is offline   Reply With Quote
Old 08-18-2004, 10:46 PM   #1863
etzkev's Avatar
www.putnampropulsion.com
My LHS carries them too.
-Kevin
Old 08-19-2004, 12:12 AM   #1864
etzkev:
Just wanted to point out that with proper set up the putnam green brushes aren't a bad choice even for budget conscious racing. Just don't run green/green!
If you haven't tried them yet give them a go, i've tried just about every brush I can get my hands on and run the putnams pretty much exclusively at the moment.
Slider is offline   Reply With Quote
Old 08-19-2004, 12:27 AM   #1865
JayBee's Avatar
Trader Rating: 31 (100%+)
etzkev:
Are you sure?
I was just at a race this weekend, and a buddy af mine was doing exactly that - running putnam greens. This was on a Monster-based stock and he TQ'd AND GOT THE WIN in the main.
Go figure... all I know is, is that the Putnam brushes are the "DU-DU", AND I'M GET'N ME SOME.
- jaybEE
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 08-19-2004, 12:32 AM   #1866
fatdoggy's Avatar
R/C Tech Charter Subscriber
Slider - I asume you mean "don't use green/green springs"? Nobody runs that for TC anyway, for 1/12th green/green or green/blue springs works great though.
As far as the putnam green brushes I like them alot, they last a long time and give good power. I run them on both the + and - and they work great. The comm wear is a little higher then 767's but not too bad. As long as you have a comm lathe who cares.
fatdoggy is offline   Reply With Quote
Old 08-19-2004, 12:44 AM   #1867
fatdoggy:
I mean't budget conscious racers shouldn't use Putnam Green Brushes on the + and -. With a Putnam Green on the + and a blue on the - you'll get just as much power as green on both and much better brush life.
JayBee:
i agree Putnams are where its at! Has your friend tried putting a putnam blue on the -. i played around with them on a friends dyno and found that I could get the same power using a blue on the - with much less wear on both the com and the brush. Usually going up one spring grade on each side from what you would usually run with other brushes combined with a Putnam Green on + and a Blue on - gave the best results, for monsters anyway.
Old 08-19-2004, 12:56 AM   #1868
JayBee's Avatar
JayBee:
i agree Putnams are where its at! Has your friend tried putting a putnam blue on the -. i played around with them on a friends dyno and found that I could get the same power using a blue on the - with much less wear on both the com and the brush. Usually going up one spring grade on each side from what you would usually run with other brushes combined with a Putnam Green on + and a Blue on - gave the best results, for monsters anyway. [/B]
As far as putting a Putnam Blue on the -, I don't think so but I'll make sure to suggest it to him; hell not only that, I want to try it myself, he can't have all the glory
THANKS DUDE, keep us posted on other pointers that you've found with stock motors......
- jaybee
Old 08-19-2004, 01:40 AM   #1869
Korey Harbke's Avatar
I have tried it, I dont like it in my stock motors. I run that in my Chameleon 2 motors though because it holds up better through the run and they wont fade.
For Stock I run green green to maximum performance possible. Yes you may be able to "almost" get the same power, but I have found on a turbo dyno that my motor worked best with putnam greens and red/red springs. Those were tweaked and measuered with a fiddle stick. I just dont remember what the numbers were but I think they were along the lines of 6.5 FS units on the positive, and the neg was 6.0 FS units.
I was geared at a 5.7 Final Drive ratio. And to let everyone know this track was BIG! There is the motor setup that had so many people at the this particular race asking. Oh and one other thing, I got 8 runs easy on putnam greens and com looked like it was barly broken after each run. Com was only skimmed (very lightly) once in 8 runs. I havent dynoed it yet, but it's fast, thats all I know. the fastest lap that I know of in 19T was a 18.3 and I pulled an 18.8 in stock on a huge track where 19t's overall horsepower would prevail.
-Korey
Xray - RC America - Hudy - Apex RC - LRP - Protoform - AVID - 1Up Racing - Xenon - Xpert - Sanwa - RC Mission America - SpeedZombi - Slapmaster Tools - Turtlemaster Racing - Seattle RC Racers
Korey Harbke is offline   Reply With Quote
Old 08-19-2004, 02:19 AM   #1870
Sushi Boy:
I'm interested in whether you tweaked the red springs to be stiffer on the positive or weaker on the negative? I don't have my fiddlestick yet, it should be here next week. I've just been using un tweaked springs and found that most of the time a purple on + and a red on - was best.
I'd be interested to see how much performance varied at the end of a run (ie when the motor has reached the highest temp it would during a race) with your lighter red/red springs versus my heavier purple/red. My motors are always strong at the end of a race and I always attributed this to my spring combo being slightly heavier than most peoples.
As for using Green/Green brushes I might have to do a little more experimenting with this. When I last had access to a dyno I found that I got exactly the same power with the green/blue brushes as the green/green. If you can get more using greens alone I might have to play with this a bit for big meets, you can never have too much power!
Old 08-19-2004, 12:37 PM   #1871
I just went and checked my motors springs and indeed they were 6.5 FS units on the positive and 6.0 on the negative. I lost alot of my punch when I went to a stiffer spring. As per big Jim, stiffer springs act like a drag brake, makes the motor heat up more, and ends up slowing the motor down anyways. My lap times were very consistant from the beginning to the end and the motor felt the same after the peak went off the batteries (which is normal). Yes, you should be able to use green/green and get increased power. That is all from my past experiences and some team putnam guys have told me, and on a turbo dyno. hope this helps ya out!
Old 08-19-2004, 05:08 PM   #1872
etzkev's Avatar
That is some great input. I usually run Purple + and Red -, like alot of other people. On the other hand, a friend of mine is almost always in the top 3 in Stock A actually SWEARS by using double green springs. I am going to try it out again, and give it a good testing.
Thanks,
Kevin
Old 08-26-2004, 07:07 PM   #1873
i just bought some epic replacement armatures for a couple of my older practice motors. I'm just wondering if anyone knows whether the standard replacement arms sold by trinity/epic are balanced?
I bought 4 arms and none of them has any drill balancing holes at all. They're the roar legal arms so none of them is epoxied, which I take it means they are unbalanced.
I can't see all four of them being perfect naturally balanced arms when they are sold as standard replacements not even pro spec arms.
Old 08-28-2004, 11:02 AM   #1874
etzkev's Avatar
Hey guys,
I got a quick question. Epic makes two non quad magnet stock motors. One is called the "Epic ROAR Stock Motor" and the other is the "Epic Stock Motor". Which one is the binary arm in a monster can? And I'm guessing the other is basically a monster?
Thanks,
Kevin
Old 08-28-2004, 11:04 AM   #1875
Moderator
StephenSobottka's Avatar
Send a message via AIM to StephenSobottka
The epic roar stock is the binary arm in a monster can. Team1 is calling the Asassin to distinguish it from the other motors.
~~Stephen Sobottka~~
SMC Racing
StephenSobottka is offline   Reply With Quote
19T Motor Forum Korey Harbke Electric On-Road 550 04-11-2009 08:27 AM
Stock motor sale !!!!CO27,P2k Pro, Monsters stock Marcos.J R/C Items: For Sale/Trade 36 06-27-2006 06:26 AM
Mod Motor forum Taz_S Electric On-Road 58 11-28-2003 12:58 AM
Stock Motor Forum JLMG1971 Electric On-Road 2 10-22-2002 03:07 AM
Stock Motor forum Taz_S Electric On-Road 62 09-14-2001 12:32 PM
