Old 08-03-2004, 02:07 AM   #1801
DOMOisCOOL's Avatar
R/C Tech Charter Subscriber
Send a message via ICQ to DOMOisCOOL Send a message via AIM to DOMOisCOOL Send a message via Yahoo to DOMOisCOOL
Yes, and it will also depend on driving preference.
Remember, the pinion/spur gearing will be different because everyone's internal gear ratio is different, but in the end, the FDR will be pretty close.
DOMOisCOOL is offline   Reply With Quote
Old 08-03-2004, 12:29 PM   #1802
JohnMatrix's Avatar
Send a message via AIM to JohnMatrix
Originally posted by JayBee
Are you recommending that FDR because that's how you like to gear YOUR Monsters or because of the track that I'm describing to you? I'm not questioning your viewpoint, just trying to understand your angle . Do I make sense
-JayBee
I'm just saying if your motor is running to hot that you need to gear down.
These motors only have 5-7 runs in them before the magnets start to wear and the hotter you run the motor the faster they wear.
Also the hotter your motor the less performance so as your motor gets hotter in the race the worst it will do.
JohnMatrix is offline   Reply With Quote
Old 08-03-2004, 12:48 PM   #1803
JayBee's Avatar
Trader Rating: 31 (100%+)
Post
GOTCHA!!
- JayBee
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 08-10-2004, 01:35 AM   #1804
donoman's Avatar
Send a message via Yahoo to donoman
Hi, I just wanted someone to verify for me these articles of information:
Average ideal FDR for
Monster motor: 7.5
Orion Stock core 6.25?
I'm running the Orion Stock at 6.75 now (64 pitch, 100T spur, 37T pinion) and it already gets hot after running on an oval. Might be cuz it's full-power 90% of the time, but is this wrong?
Previously, someone suggested 6.25 which would give me a 40T intended pinion. Uh, will this blow my Orion Stock Core up?
donoman is offline   Reply With Quote
Old 08-10-2004, 03:32 AM   #1805
Harg's Avatar
Wink
Try narrow brush trick to cure heating. Orion Core is similar to MVP. FDR could be right.
More info (hard to find correct thread) about narrow brush can be found Big Jim motorforum . Lot of reading about motors.
Harg is offline   Reply With Quote
Old 08-10-2004, 03:36 AM   #1806
Can some give me a link to a site which gives me rollout and drive ratio
Chazz is offline   Reply With Quote
Old 08-10-2004, 03:38 AM   #1807
DOMOisCOOL's Avatar
www.gearchart.com
Old 08-10-2004, 03:47 AM   #1808
Old 08-10-2004, 05:38 AM   #1809
Team Duratrax's Avatar
Send a message via MSN to Team Duratrax
Are Orion brushes ok in a P2K2 PRO? or should i just stick with the original 4499's?
Team Duratrax is offline   Reply With Quote
Old 08-10-2004, 09:22 AM   #1810
etzkev's Avatar
Send a message via AIM to etzkev
I'd stick with the 4499's.
etzkev is offline   Reply With Quote
Old 08-11-2004, 04:11 AM   #1811
Can anyone explain to me how you would make a P2K2 PRO faster then it is.I have the original springs still in it and i have Orion brushes and how do allign teh motor like teh armature and the brushhoods.
Thanks.
Old 08-11-2004, 10:18 AM   #1812
Trader Rating: 18 (100%+)
Send a message via AIM to Roberto Falcon
are these good brushes and springs for my monster STOCK .. putnam's greens brushes and red trinity springs on + and - . let me know have a race this friday .
Roberto Falcon is offline   Reply With Quote
Old 08-11-2004, 10:34 AM   #1813
fatdoggy's Avatar
LoSi xXx S - Putnam brushes work great in the monster. For the brushes you may want to try a green + and blue - so they last a little longer. The posted springs will work fine.
Team Duratrax - http://www.motortuningsecrets.com/tunestockmotor.html
fatdoggy is offline   Reply With Quote
Old 08-11-2004, 10:52 AM   #1814
Super Moderator
Trader Rating: 17 (100%+)
can someone give me the formula to calculate rollout in both mm and in. thanks
Tekno|JConcepts|TeamTrinity|BOOMrc
Bob Barry is offline   Reply With Quote
Old 08-11-2004, 11:29 AM   #1815
fatdoggy's Avatar
rollout = (tire diameter(mm or inches) x 3.14) / (Overall gear ratio)
19T Motor Forum Korey Harbke Electric On-Road 550 04-11-2009 08:27 AM
Stock motor sale !!!!CO27,P2k Pro, Monsters stock Marcos.J R/C Items: For Sale/Trade 36 06-27-2006 06:26 AM
Mod Motor forum Taz_S Electric On-Road 58 11-28-2003 12:58 AM
Stock Motor Forum JLMG1971 Electric On-Road 2 10-22-2002 03:07 AM
Stock Motor forum Taz_S Electric On-Road 62 09-14-2001 12:32 PM
