Old 07-04-2004, 05:30 AM   #1696
Originally posted by KilRuf
Here is my Binary... has 36 laminations. Maybe I got a fluke with the Epic Roar Stock. I beleive I got it a couple months ago. It's not the Pro version either. Maybe I'll just have to buy another Roar Stock and count the lams....
That motor is also epoxy balanced. It aint legal.
David Root is offline   Reply With Quote
Old 07-04-2004, 05:47 AM   #1697
mafiaracers's Avatar
Trader Rating: 22 (100%+)
Send a message via AIM to mafiaracers Send a message via MSN to mafiaracers
Someone mentioned asian motors a little higher up on the page.....I am actually in Japan right now. Anyway, I went to the Tamiya R&D headquarters today and their test\racetrack. I bought a Tamiya stock motor. Its 23 turns and has a pretty sweet endbell and can design. It also used standup brushes. Im gonna tune it when I get back to the states and see how it turns out. I have a hunch that itll rip!...it looks fast, and the box says its fast, so.....
mafiaracers is offline   Reply With Quote
Old 07-04-2004, 04:21 PM   #1698
JimmyMac's Avatar
David Root, my pic and post says that this arm was the Binary. Which I know is not legal... but on the page before (56)... I have the pic of my Epic Roar Stock (which is Roar Legal) that also has 56 laminations... which my last post refers to as to maybe I have a fluke since everyone is saying the Roar Stock is suppose to be 58 laminations.... Sorry for any confusion....
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
JimmyMac is offline   Reply With Quote
Old 07-04-2004, 06:25 PM   #1699
etzkev's Avatar
Send a message via AIM to etzkev
You mean 36 and 38 laminations. I think you got confused with the page numbers!
etzkev is offline   Reply With Quote
Old 07-05-2004, 12:08 AM   #1700
JimmyMac's Avatar
haha, yes I did.. haha... Thanks again... for any confusion.. 36 and 38... not 56 and 58... derrrrrt!
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
Old 07-05-2004, 04:35 AM   #1701
OK, Phew gotchya!
I have some handout motors that have 2 magnets, chrome can and purple endbell. I THINK 40 lams, but are epoxy balanced. They are really fast but not legal for me to use either. Jim Greenmyer is now workig for trinity again, so I don't think we will be seeing more motors with less laminations.
Old 07-05-2004, 12:48 PM   #1702
hogdaddy77's Avatar
Default bushing/bearing
Can the bearing in my monster stock be replaced with a bearing..and would it be ROAR leaga?
hogdaddy77 is offline   Reply With Quote
Old 07-05-2004, 12:50 PM   #1703
fatdoggy's Avatar
R/C Tech Charter Subscriber
All roar legal stock motors use bushings. Bearings are illegal in stock.
fatdoggy is offline   Reply With Quote
Old 07-05-2004, 01:26 PM   #1704
hogdaddy77's Avatar
I thought I saw in the last ROAR mailing that they changed it to allow bearings..perhaps I mis-read it, as I didnt see it on the ROAR webpage just now
Old 07-05-2004, 01:27 PM   #1705
HELL FROZE OVER
You can put bearings in a Monster. No it will not be ROAR legal but for practicing it'll make for a more efficient motor
The Black Kat is offline   Reply With Quote
Old 07-05-2004, 02:59 PM   #1706
JimmyMac's Avatar
Hmmm does this mean he now likes overhead springs? Or just uhhh I'll shut up.....
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
Old 07-05-2004, 09:18 PM   #1707
tornado
Guest
Posts: n/a
Originally posted by The Black Kat
HELL FROZE OVER
I do put bearings in all my monsters.....just for zipping around.... the monsters last longer too.
Old 07-06-2004, 07:58 PM   #1708
JayBee's Avatar
Trader Rating: 31 (100%+)
Post
I just finished putting the red and green springs in my Monster also with the Trinity 4499 brushes. The springs, I got from Agressive R/C Technologies in Black Diamond, WA. Anyone know anything about these guys? The green overhead springs are 9 oz. and the red are 11 oz., are these rates correct? The springs came in pairs, but now I have 1 green for the positive and 1 red for the negative. Should I try this sometime? The change definitely made a difference, is there anything else I can do to make it faster?
I sprayed the bushings out too, but I used some of Trinity's comm oil to re-lube them. Was this ok
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 07-06-2004, 08:31 PM   #1709
Korey Harbke's Avatar
Whats up Jaybee,
I think the springs that Aggressive uses are just trinity springs. Ususally the ratign is just an "in the ballpark" kinda rating. Most motor springs nowadays are very very very inconsistant. Thats why I use a Sonic Fiddle Stick. They give a reading of how stiff a spring is while it is on the motor, and it also takes into acount how big your comm is, and how long your brushes are. You can get them from Paradigm Racing.
Now about using the softer spring on the pos side. That usually never works to well. Ususally most fo the electricity travels through the positive end of the motor, so you need a stiffer spring to keep it from getting "blown" away from the comm and prevent arching, glazing, and excessive com wear. So always run a stiffer spring on the pos side, or run equal rate spring on both ends.
Personally, I always use Tribo for my bushings. It's some uber cool lubricant that Team Paradigm sells as well. I use it when breaking in bushings, and as a general lube. Probably the most important thing with any motor is to align the brush hoods properly. Sometimes it takes a while, but it's worth it. It reduces com and brush wear, and gives a major boost in power. Hope this helps dude.
-Korey
Xray - RC America - Hudy - Apex RC - LRP - Protoform - AVID - 1Up Racing - Xenon - Xpert - Sanwa - RC Mission America - SpeedZombi - Slapmaster Tools - Turtlemaster Racing - Seattle RC Racers
Korey Harbke is offline   Reply With Quote
Old 07-06-2004, 10:02 PM   #1710
JayBee's Avatar
Post
What's up Korey,
thanks for the Team Paradigm heads up. I'll try that stuff.
I entered my 1st race Sat., and I SUCK , but racing more will smoooth that out.
Hey, where can I get the fiber board looking washers that come in the monster?
JayBee
19T Motor Forum Korey Harbke Electric On-Road 550 04-11-2009 08:27 AM
Stock motor sale !!!!CO27,P2k Pro, Monsters stock Marcos.J R/C Items: For Sale/Trade 36 06-27-2006 06:26 AM
Mod Motor forum Taz_S Electric On-Road 58 11-28-2003 12:58 AM
Stock Motor Forum JLMG1971 Electric On-Road 2 10-22-2002 03:07 AM
Stock Motor forum Taz_S Electric On-Road 62 09-14-2001 12:32 PM
