Old 06-28-2004, 06:48 PM   #1681
the new epics are suffering like the fukayama mako. those knuckle heads are drill balancing so deep that when the armature revs higher the segments are flying arpart due to centrical force. i still prerfere the epics, just buy ones that aren.t balanced. in my experience with these motors, the pro ones don't perform as well as the oem non pro motors. on the non pro with red springs and 4499 brushes it revved 3000 more rpms. the armatures are smaller than the monsters which is why they rev higher.
trigger is offline   Reply With Quote
Old 06-28-2004, 06:54 PM   #1682
in any case gear down one or two than what you would gear your monster. and yes whatever you're geared at, these suckers get hot. their ability to rev is due to their smaller stack of segments. go a head and compare. the monster is bigger. a binary arm is in between the epic and monsters.
Old 06-28-2004, 07:06 PM   #1683
i know a bunch of you are thinking, a balance arm is better than one that isn't. true but if the holes are to deep you'll result in a blown segment like kilruf. until epics fixes the problem think of it like this: more material more torque, and less worries about blown motors.
Old 06-28-2004, 08:13 PM   #1684
popsracer's Avatar
Default Epic Stock Balancing
Guys;
Actually the Non-Pro Motors are balanced also, so I'm not sure balancing wise if there is any difference between the two.
Either way with as few laminations as these motors have, I find they make more power with the least amount of drilling into the stack as possible.
Motors like the P2K2 that have more metal in the stack, don't seem to be effected as much by the drilling.
popsracer is offline   Reply With Quote
Old 06-28-2004, 08:48 PM   #1685
dontfeelcold's Avatar
Trader Rating: 21 (100%+)
that xenon 23t on the left, is the timing changed on the armature. look att the angle of the comm segments
dontfeelcold is offline   Reply With Quote
Old 06-28-2004, 08:51 PM   #1686
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Timing stays the same..... Kind oof hard to gear and tune with this type of comm
-Dave
Ȼ4.5 Centro+α ◊ TRF 501ӽ ◊ TRF 502ӽs ◊ TRF 503 ◊ TRF 511 ◊ TRF 201ӽr ◊ TRF 211ӽ
B5m ◊ T5m ◊SC5m ◊ B64deez nutz
Speedway PAL ◊ SDRC ◊ Shop UFO ◊ SMC
JDM_DOHC_SiR is offline   Reply With Quote
Old 06-28-2004, 09:11 PM   #1687
Yokomo Aust's Avatar
Default Re: Re: You misunderstood me.
Originally posted by JDM_DOHC_SiR
You mean like this Xenon 23T rotor on the left
-Dave
That is it. Thats what i am looking for for a 27 turn motor. I guess i could attempt to re wind it. I am going to try and find a 27 turn i dont like my luck becausre they dont run 27t in Asia.
Thanks heaps for the pick was a little blurry but who cares.
Yokomo Aust is offline   Reply With Quote
Old 06-28-2004, 09:14 PM   #1688
Default Re: Re: Re: You misunderstood me.
Sorry I took that shot late when the lightiing wasn"t good
But I have a better shot of it if you want..
-Dave
Old 06-28-2004, 09:43 PM   #1689
http://www2.towerhobbies.com/cgi-bin...8&I=LXBHF6&P=K
Has anyone played around with one of these? Any comments
The Black Kat is offline   Reply With Quote
Old 06-28-2004, 09:48 PM   #1690
Team EAM
EAMotorsports's Avatar
Trader Rating: 79 (100%+)
Send a message via AIM to EAMotorsports
The problem with the Fukuyama balancing is taken care of....No more problems. I do think that they were replacing the ones that this happend to out of the first batch as well.
EA
Contact Us
Team EAM, Our Facebook
Team EAM | Xray | RCAmerica | Hudy | APEX Raceway and Hobbies | RC Mission | Killer Concepts | AVID | Hobbywing.
EAMotorsports is offline   Reply With Quote
Old 06-28-2004, 09:48 PM   #1691
no but if they are any thing like the core stock, i'll be torquey i bet. not sure on the rpms but those things generaly run hot any way. i think the monsters, epics(2 or 4 mag),and p2ks are the top runners.
Old 06-28-2004, 10:26 PM   #1692
JimmyMac's Avatar
Here is my Binary... has 36 laminations. Maybe I got a fluke with the Epic Roar Stock. I beleive I got it a couple months ago. It's not the Pro version either. Maybe I'll just have to buy another Roar Stock and count the lams....
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
JimmyMac is offline   Reply With Quote
Old 07-03-2004, 11:58 PM   #1693
xray racer's Avatar
Trader Rating: 22 (100%+)
hey
i have a reedy mvp
just wondering if heat affects them as much as it does epic motors???
no matter what i do.. my mvp always seems to run hot... any tips???
thanx
robbie
Robbie Lloyd
Yokomo * HobbyWing * Sanwa
xray racer is offline   Reply With Quote
Old 07-04-2004, 12:25 AM   #1694
Korey Harbke's Avatar
Do the big jim narrowed brush trick. That will lower operating temps and increase torque at the expense of rpm. The magnets are much better than all of epic's stock motors, so they will handle heat alot better.
-Korey
Xray - RC America - Hudy - Apex RC - LRP - Protoform - AVID - 1Up Racing - Xenon - Xpert - Sanwa - RC Mission America - SpeedZombi - Slapmaster Tools - Turtlemaster Racing - Seattle RC Racers
Korey Harbke is offline   Reply With Quote
Old 07-04-2004, 01:23 AM   #1695
Trader Rating: 70 (100%+)
Send a message via AIM to TexRacer
Guys on Reedy MVPs,Orion Core's and Peak Hellfire's it's all about the BIG JIM brush trick which is taking a small amount off each side of the brush narrowing it.
Use reedy 767 or in alot of racing I run a 767 on the + and then a 766 on the - and drill a hole in the middle of the 766.
My cores work awesome in offroad and small to medium sized sedan tracks.I like the following motor's due to the magnet's being 10x's better and not wearing out.
*****Look me up on Ebay. I will have alot of stuff going up as 7/7/2016. User name is Dalracer.**** This is going to be a BIG ONE!!!!!!
Just wanted to say Thanks to RcTech for all these years of Great Information.
TexRacer is offline   Reply With Quote
19T Motor Forum Korey Harbke Electric On-Road 550 04-11-2009 08:27 AM
Stock motor sale !!!!CO27,P2k Pro, Monsters stock Marcos.J R/C Items: For Sale/Trade 36 06-27-2006 06:26 AM
Mod Motor forum Taz_S Electric On-Road 58 11-28-2003 12:58 AM
Stock Motor Forum JLMG1971 Electric On-Road 2 10-22-2002 03:07 AM
Stock Motor forum Taz_S Electric On-Road 62 09-14-2001 12:32 PM
