Old 06-24-2004, 04:25 AM   #1666
Default Roar
Here is what I know,
Roar says you can not switch arms in cans or endbells. They are verry descriptive about the motors.
Roar says no epoxy balanced motors, and no quad magnet stock motors.
I bought some hand out motors that had a chrome can and an epoxy balanced arm. They were basicly monsters. REALLY fast, but not ROAR legal
Here is some discussion on it
http://www.wnyrcinfo.com/site/module...ewtopic&t=2842
David Root is offline   Reply With Quote
Old 06-24-2004, 11:11 AM   #1667
etzkev's Avatar
Send a message via AIM to etzkev
Originally posted by tornado
Isit ? Gotta check with ROAR .
Yeah, that is called a "Hybrid" motor, which is illegal. This has been gone over many times before.
-etzkev
etzkev is offline   Reply With Quote
Old 06-24-2004, 11:50 AM   #1668
Epic is releasing a ROAR legal stock
Binary2 arm in a Monster can basically. So if you like that combo and your track is tight on ROAR rules....theres yer solution
The Black Kat is offline   Reply With Quote
Old 06-24-2004, 02:27 PM   #1669
popsracer's Avatar
They're out already (I have one).
More rpm and less torque than a regular MS. I have to gear it about 2-3 teeth smaller than my MS's.
Overall, I think that the outlaw version should be a better motor if your track allows them. Even more rpm, with about the same torque and no balance holes to reduce overall power (watts).
popsracer is offline   Reply With Quote
Old 06-24-2004, 09:16 PM   #1670
Geez, I can't get smaller pinion on my XXXT now ! I want torque! Back to the GM3 or P2K2 !
Old 06-24-2004, 09:23 PM   #1671
Team EAM
EAMotorsports's Avatar
Trader Rating: 79 (100%+)
Send a message via AIM to EAMotorsports
There are 3 different arms. Binary arm 36 laminations, ROAR Stock arm 38 laminations and Monster arm 40 laminations. The binary is too short (short stack wire lenght) and is epoxy balanced. The other two are long enough and drill balanced so they are both roar legal arms.
EA
Contact Us
Team EAM, Our Facebook
Team EAM | Xray | RCAmerica | Hudy | APEX Raceway and Hobbies | RC Mission | Killer Concepts | AVID | Hobbywing.
EAMotorsports is offline   Reply With Quote
Old 06-24-2004, 10:08 PM   #1672
Yokomo Aust's Avatar
Default Ti coated armatures
Has anyone tried to titanium coat the arm of a stock motor. If the theory is correct the titanium coating will reduce friction on the bushes and will reduce the heat inside the can to give a much better power over the duration of the whole race.
Yokomo Aust is offline   Reply With Quote
Old 06-25-2004, 04:42 PM   #1673
popsracer's Avatar
Default Re: Ti coated armatures
The problem is the coating will add to the outer dimensions of the surfaces and the clearance between the shaft and bushings is already at a minimum.
I have seen some "Specially" tuned Arms that have the stack lamination polished. I am assuming this is to reduce windage in the can. Hummm......
Old 06-25-2004, 06:36 PM   #1674
Default I have thought of that
I thought that the arm could be trued to compensate for the addition of the coating of the bush could be enlarged. It could be dont but would it result in a benefit at all is the question. People always dicourage you with " That will only give you .01 of a second whats the point" But i say it's the .001 of a second that add up to the seconds.
Just a thought.
Old 06-26-2004, 05:08 PM   #1675
Location: Built By The Racers For The Racers. Corona CA
I know this is the stock thread but could not find the 19T one. Quick question.
What is a good brush and spring combo for the Chameleon Pro 2 19T Spec. Can anyone help?
R/C HEAT is offline   Reply With Quote
Old 06-26-2004, 05:18 PM   #1676
etzkev's Avatar
Try Trinity 4499's or Reedy 767's with double Red's. I'm not EXACTLY sure what to go with for a Chameleon, but that should be somewhat close, and it will give you an idea of what to do.
-Kevin
Old 06-27-2004, 12:19 AM   #1677
Super Moderator
Grizzbob's Avatar
Default Re: I have thought of that
Just a thought.
If I understand your question right, you're talking about using titanium as the comm surface, instead of copper? If that's it, then I don't think that would do any good at all, what little improvement you might gain in wear(or even big gain), you'll more than lose in electrical resistance. Copper conducts electricity MUCH better than titanium does(pretty much only silver is better), so the the increase in resistance by using titanium would likely make the motor lose a BUNCH of power, far too much to be of any good. Having said that, I WOULD be interested to see if it were possible to have a SILVER plated comm, now THAT would have some intriguing posibilities....
Bob Seay
Tamiya TRF417, TA05v.2, TRF211XM, M-05ver.2R, XRAY X12, Associated B5m Factory Lite
Go Pokes!!!
Grizzbob is offline   Reply With Quote
Old 06-27-2004, 12:29 AM   #1678
Default You misunderstood me.
I am talking about the shaft that runs inside the bushess at the end of the can and end bell. The parts that all Roar stock 27t motors have instead of bearings. Coating the shaft that the pinion attaches to and runs through these bushes where the most amont of friction beside the brushes against the com which is required.
Old 06-27-2004, 01:40 AM   #1679
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Default Re: You misunderstood me.
You mean like this Xenon 23T rotor on the left
-Dave
Ȼ4.5 Centro+α ◊ TRF 501ӽ ◊ TRF 502ӽs ◊ TRF 503 ◊ TRF 511 ◊ TRF 201ӽr ◊ TRF 211ӽ
B5m ◊ T5m ◊SC5m ◊ B64deez nutz
Speedway PAL ◊ SDRC ◊ Shop UFO ◊ SMC
JDM_DOHC_SiR is offline   Reply With Quote
Old 06-28-2004, 06:41 PM   #1680
JimmyMac's Avatar
My Epic Roar Stock has 36 laminations.... This one had deep drill balance holes. Not sooo good as you can see....
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
JimmyMac is offline   Reply With Quote
19T Motor Forum Korey Harbke Electric On-Road 550 04-11-2009 08:27 AM
Stock motor sale !!!!CO27,P2k Pro, Monsters stock Marcos.J R/C Items: For Sale/Trade 36 06-27-2006 06:26 AM
Mod Motor forum Taz_S Electric On-Road 58 11-28-2003 12:58 AM
Stock Motor Forum JLMG1971 Electric On-Road 2 10-22-2002 03:07 AM
Stock Motor forum Taz_S Electric On-Road 62 09-14-2001 12:32 PM
