STOCK motor forum >
STOCK motor forum
STOCK motor forum
Old 10-30-2001, 08:23 PM
  #151
SPEEDO- a man after my own heart, I personnally use the same tricks that Jim gives us for free, and tune my own motors, never dynoed the yet, but hey I don't have a dyno.....so it's seat of the pants as to how well i did, but I have very rarely been disappointed....
IMPACTPLAYR is offline
Old 10-31-2001, 06:50 AM
  #152
Super Moderator
Kraig's Avatar
Trader Rating: 81 (100%+)
fyi, you will be able to purchase Team 1 motors on line pretty soon.
Kraig is offline
Old 11-01-2001, 12:49 PM
  #153
Default Stock Motor Cleaning Questions...
I'm new to the hobby. So I have many questions:
1. What do i need to clean a stock motor?
2. How and what do I clean?
I have a P2K Pro motor. Any tips or step by step instructions would be greatly appreciated.
Myke is offline
Old 11-01-2001, 03:34 PM
  #154
Speedo's Avatar
You'll need a can of motor spray. Take the motor appart, and spray everything down. Replace the brushes after every 4-15 runs. If you don't have a lathe, get one, or get someone else to true the comm for you. Also, break the motor in at 3 volts for a few minutes whenever you true the comm or replace the brushes.
Speedo is offline
Old 11-01-2001, 04:09 PM
  #155
Simon K's Avatar
Wink
Buy a fibreglass comm cleaning stick. Use it after every run.
Simon K is offline
Old 11-01-2001, 07:17 PM
  #156
redsand's Avatar
Default mod motor question
I put in a different brand armature into a motor cam the other day, yet it ran backwards. Would it be safe if I just switch the wire, black goes to + and red is with - side ? Or perhaps I turn it 180 deg ?
redsand is offline
Old 11-01-2001, 07:20 PM
  #157
Trader Rating: 27 (100%+)
You have the endbell reversed. Turn the endbell 180 degrees and the motor will rotate correctly.
MDawson is offline
Old 11-02-2001, 08:32 PM
  #158
zxt
zxt's Avatar
Default Tamiya motor question
I have a Tamiya motor which I got from a friend...its quite fast.
I dont know how many turns it has but I think its around 19-23...considerably faster around 30 percent from any stock rebuildables...like if I put the motor on the same car with stock rebuildables and race...it will be at the end of the 60 foot race while the other is only at the 40 feet mark...can u picture my comparison?
Also it has timing adjustment....has anyone experienced this motor? Thanks
zxt is offline
Old 11-03-2001, 01:44 AM
  #159
dtm
dtm's Avatar
zxt- Any numbering on the Tamyia motor at all? shell colour etc... Its a little difficult to tell which motor you are talking about!
dtm is offline
Old 11-03-2001, 03:27 AM
  #160
zxt
zxt's Avatar
thew endbell is black, the can is silver gray with timing adjustments...I looked at the endbell and its says Dynatech 020...how many turns is it?
zxt is offline
Old 11-03-2001, 03:53 AM
  #161
zxt
zxt's Avatar
Default HELP!
Now I cant get the pinion out of that motor...the space in that little screw that you put your tool into is bigger now...so my tool just wont get it to turn...how do I force it?
Now I cant take motor out of my RS4 Sport because of the pinion...
anybody got any ideas?
zxt is offline
Old 11-03-2001, 07:25 AM
  #162
RCTech Member #2
TSR6's Avatar
Bolink makes a pinion puller. Part # BL-6014 Aprox $9.95
TSR6 is offline
Old 11-03-2001, 08:13 PM
  #163
Trader Rating: 82 (100%+)
TSR6: do you have a picture of that pinion puller? i went to tower and there was no pic and description. i also went to bolink's site and it was down.
marvi is offline
Old 11-03-2001, 10:23 PM
  #164
David Galdo's Avatar
Trader Rating: 15 (100%+)
The pinion puller I have is a 'C' shape with an opening only large enough to fit the shank of the pinion through it. Then there is a knob like screw that is used to push the armature shaft from the pinion.
Here is another type of puller sold by sears.
It sucks that you'll have to buy this tool you may only use once or twice for this purpose.
David Galdo is offline
Old 11-04-2001, 05:42 AM
  #165
RCTech Member #2
TSR6's Avatar
marvi - Its shaped like a " C " with the little screw going though the middle. Its in Oct 01 RCCA in teh tool guide.
TSR6 is offline
