Old 06-14-2004, 01:05 AM   #1621
fatdoggy's Avatar
R/C Tech Charter Subscriber
As long as you gear your monster correctly it should work fine. If it's a tight track you may want to try red/red springs or if you have a lathe and don't care about comm/brush wear then maybe purple/red.
fatdoggy is offline   Reply With Quote
Old 06-14-2004, 07:40 AM   #1622
mafiaracers's Avatar
Trader Rating: 22 (100%+)
Send a message via AIM to mafiaracers Send a message via MSN to mafiaracers
If you're looking for pure torque, silver on the posative and purple on the negative with a high silver brush. However, you'll have to fully rebuild it after each run.
mafiaracers is offline   Reply With Quote
Old 06-14-2004, 12:02 PM   #1623
imjonah's Avatar
Default Hole drilled in brush
I bought 2 binary stock "outlaw" motors on Ebay recently, from a company that supposedly 'tunes' thes motors.
I checked the brushes on one of them and both brushes had 1/64the of an inch holes drilled in the center of the brush face.
anyone know the purpose of this drill hole? The second identical motor I bought at the same time did not have these holes
imjonah is offline   Reply With Quote
Old 06-14-2004, 03:17 PM   #1624
Default I drill holes
I don't know about them, but I have found a 5/64 or #42 bit with a hole in the center of the brush keeps the comm and brushes looking a lot better after a few runs. FOR ME it seems to prolong performance and I don't get arc marks on the brushes or com. I drill all of my brushes. I do not have a serrator.
David Root is offline   Reply With Quote
Old 06-14-2004, 03:34 PM   #1625
Default Holes
Brushes make the most amount of power along the outermost edges of the brush. So, by drilling a hole in the center, you force the power to stay along the outermost edges of the brush forcing the brush to maintain maximum power output. The other advantage to a hole brush is that you can use a lighter spring and still achieve the same effect of a full face brush with a heavy spring.
Old 06-14-2004, 06:32 PM   #1626
yodace's Avatar
[i]
Got any tips you'd like to share for the binary? Other then golds or 2152's. [/B]
More info on the gold's and 2152's been away awhile.
yodace is offline   Reply With Quote
Old 06-14-2004, 10:06 PM   #1627
fatdoggy's Avatar
Golds are from from team hurricane and 2152's are from team paradigm.
http://www.teamhurricane.net/
http://www.team-paradigm.com/
Old 06-15-2004, 12:44 AM   #1628
Brian McGreevy's Avatar
Send a message via AIM to Brian McGreevy Send a message via Yahoo to Brian McGreevy
Fatdoggy, you got PM
USVTA Member #211
Support Formula SAE - get kids into engineering!
http://motorsports.illinois.edu/
Brian McGreevy is offline   Reply With Quote
Old 06-15-2004, 08:10 AM   #1629
yodace's Avatar
fatdoggy thanks for the info..
I was also wondering what the stuff is people are using to polish their bearings, and what tool their using to do so..?
How is this site for online shopping do they ship it pretty quick? I've heard they don't alway ship the stuff that u order from them.
Old 06-15-2004, 09:06 AM   #1630
pop out your bushings and first sand them with 400 grit, then sand with 2000. Sand on a piece of glass so it is as flat as possible. Once you've sanded a perfectly flat surface into the face of the bushing....then go to work on the inside. Roll up your 400 and sand the inside but be careful because if the hole is enlarged too much you'll get some play. Then take 2000 and do it again. Once all done, spray with motor spray, allow to dry. Then take BLUE MAGIC POLISH and rub the bushing on an old white t-shirt and it'll turn black. thats the grime and [email protected] that's coming off the bushing. Once it turns black, move to another spot and rub it on the shirt again, it will turn black. continue this until it no longer is black. Then repeat on the inside of the bushing.
Do the same process for the shaft itself and your bushings will spin like bearings.
Old 06-15-2004, 11:04 PM   #1631
JayBee's Avatar
Trader Rating: 31 (100%+)
Post
i guess i thought correctly then.... the Monster does have bushings. THANKS
JayBee is offline   Reply With Quote
Old 06-15-2004, 11:09 PM   #1632
Korey Harbke's Avatar
Jaybee-
Yes, All ROAR Approved stock motors have brass bushings. Just polish them up liek others have said and they work great. Just keep them lubed with something. What track were you going to run at? I might be able to help you out on gearing.
-Korey
Xray - RC America - Hudy - Apex RC - LRP - Protoform - AVID - 1Up Racing - Xenon - Xpert - Sanwa - RC Mission America - SpeedZombi - Slapmaster Tools - Turtlemaster Racing - Seattle RC Racers
Korey Harbke is offline   Reply With Quote
Old 06-15-2004, 11:42 PM   #1633
JayBee's Avatar
Post
Originally posted by Sushi Boy
Jaybee-
-Korey
I'm gonna be running @ the new track that just opened in Olympia-- Four Seasons R/C
Old 06-16-2004, 11:24 AM   #1634
PMR
Default Reedy 19t
Kinda new to the 19t were running here. Couple of guys are smokin me in our tracks with the same motor and gearing.Can you guys can any suggestions on how to soup up my Reedy 19t spec. Whats the best brush and spring combo?
PMR is offline   Reply With Quote
Old 06-16-2004, 12:07 PM   #1635
rod_b's Avatar
Send a message via AIM to rod_b
I run 767s and purple springs and mine runs pretty good. I have a Fantom Quad Mag 19T that came with 766s and purple springs.
rod_b is offline   Reply With Quote
19T Motor Forum Korey Harbke Electric On-Road 550 04-11-2009 08:27 AM
Stock motor sale !!!!CO27,P2k Pro, Monsters stock Marcos.J R/C Items: For Sale/Trade 36 06-27-2006 06:26 AM
Mod Motor forum Taz_S Electric On-Road 58 11-28-2003 12:58 AM
Stock Motor Forum JLMG1971 Electric On-Road 2 10-22-2002 03:07 AM
Stock Motor forum Taz_S Electric On-Road 62 09-14-2001 12:32 PM
