Old 05-31-2004, 05:54 AM   #1561
DJB
DJB's Avatar
Trader Rating: 17 (100%+)
Yeh you guys in nz have crappy finals rules as well. Hey you stock guys i run on concrete what is a good brush strength 9 or 11 oz. and do you reckon trinity 4499 brushes are good or are they crap??
Team Associated - Champions by Design
DJB is offline   Reply With Quote
Old 05-31-2004, 07:24 AM   #1562
etzkev's Avatar
Send a message via AIM to etzkev
I love the 4499's. That is basically all I use. Reedy 767's are awesome too.
etzkev is offline   Reply With Quote
Old 06-01-2004, 09:58 PM   #1563
F1Junkie's Avatar
R/C Tech Charter Subscriber
Hi -
I was wondering if there is anyone who tunes stock motors in Canada - maybe the Ontario area...???
Not really wanting to send stuff across the border - if there is anyone who knows of this service, please let me know!
Dave
F1Junkie is offline   Reply With Quote
Old 06-02-2004, 04:14 AM   #1564
Default 4499 good Brush
767 is what I use, but 4499 is next in line. Both make great power. I drill a 5/64 hole in them once the serrations wear off. This keeps the com and brushes clean with out getting arc,burn or glaze.
David Root is offline   Reply With Quote
Old 06-02-2004, 04:21 AM   #1565
DJB
DJB's Avatar
why dont you buy a serrater from eagle. ive seen one on speedtech. you can re serrate your brushes anytime you please. I dont know how small you would let them go for tho
Old 06-02-2004, 04:45 AM   #1566
Cole Trickle's Avatar
Originally posted by F1Junkie
Hi -
Dave
Even though you want the service, you might this helpfull: http://www.motortuningsecrets.com/
Schumacher Mi5 - Sanwa MT-4 / RX-462 / KO Propo PDS-2123 - Nosram 5600 X-treme Saddle Pack - LRP SPX Zero/X12 17,5 - Nosram Stealth Touch Evolution - MAAS SPS 9250
Cole Trickle is offline   Reply With Quote
Old 06-02-2004, 05:13 AM   #1567
F1Junkie's Avatar
Thanks Thomas -
Maybe I don't need it after all!
Cheers
Dave
Old 06-02-2004, 09:02 AM   #1568
Default 4505's
I do use any of the shaving or drilling tricks but everytime I use 767's I get noticably less RPM/top-end on the track but a tad bit more torque. Are you supposed to shave them (I use em strait out of the bag)
What break in methods do you guys use? I've heard 3 amps & 3 volts....I do 2 minutes of each.
The "E" brush (4499) is probably one of the better brushes there is. I use the 4505 (Cross Cut 99-Plus Brush) It seems to produce a bit more power noticably on the track & the same RPM as the 4499. It gets less life though
The Black Kat is offline   Reply With Quote
Old 06-02-2004, 09:18 AM   #1569
mafiaracers's Avatar
Trader Rating: 22 (100%+)
Send a message via AIM to mafiaracers Send a message via MSN to mafiaracers
I remember when a bunch of the Losi guys came out to our track for a race. I remember Mike Truhe breaking in his motors, because you could hear it from a mile away. He hooked them up and cranked it as high as him Pulsar would go. That thing screamed like I've never heard before! Although, he made a 3 minute job into a 4 second job.....can't argue with that...
mafiaracers is offline   Reply With Quote
Old 06-02-2004, 02:31 PM   #1570
Default IF
my brush hoods are lined up, break in takes less than 5 minutes at 3 volts. I run the motor slow (3v) with out a fan on it until the brushes are seated all the way out to all 4 corners. If its a rebuild including skim, it takes less than a minute to re seat them. I hit them with a brass wire tooth brush, then break them in. If the hoods have been whacked or something is out of line, I will see it right away by the wear pattern on them.
Old 06-02-2004, 07:57 PM   #1571
Send a message via AIM to R/C Anonymous
Default Re: 4505's
how can u do 3 amps AND 3volts each? those r two different measurements
Geoff C.
R/C Anonymous is offline   Reply With Quote
Old 06-03-2004, 01:22 PM   #1572
I'm just sayin what I heard...
ATM I'm doing 3 volts for 2 min & then I turn it to 3 amps for 2min
Anyway...I had a question about brush tweaking...What would be a better way to increase RPM via brushes? Drilling a hole in the center or shaving away 1/2 the brush (to simulate increased timing) I'm doing this to a Core so it has plently of torque...I just want a few more revs (RPM)
Can I use sandpaper to shave brushes? Or should I use a file? If I drill a hole in the brushes how big/deep should it be? How much would you guys estimate the RPM increase doing one or the other? In other words...how do I do these "mods" and which one works better in a Core stock
Thanks - Dan
Old 06-03-2004, 01:57 PM   #1573
PitCrew's Avatar
Lightbulb Laydown Brushes
Laydown brushes at full width make the most RPM. When you narrow them, it creates more torque, but less RPM.
This is per Big Jim.
PitCrew is offline   Reply With Quote
Old 06-03-2004, 05:33 PM   #1574
Okay...how would I go about drilling brushes?
Old 06-03-2004, 06:25 PM   #1575
Take a 1/16th drill bit and using your fingers, roll it gently in the desired area of the face. You can get a different effect by drilling in different areas. If you drill more to the leading edge, you'll get less free spin and a little more torque. If you drill in the center, you get a great ballance of everything (most widley used). If you drill to the trailing edge, you'll get more free spin (off power) and it will act like a timed brush but without actually trimming the brush shape.
19T Motor Forum Korey Harbke Electric On-Road 550 04-11-2009 08:27 AM
Stock motor sale !!!!CO27,P2k Pro, Monsters stock Marcos.J R/C Items: For Sale/Trade 36 06-27-2006 06:26 AM
Mod Motor forum Taz_S Electric On-Road 58 11-28-2003 12:58 AM
Stock Motor Forum JLMG1971 Electric On-Road 2 10-22-2002 03:07 AM
Stock Motor forum Taz_S Electric On-Road 62 09-14-2001 12:32 PM
