Old 05-28-2004, 11:28 AM   #1546
fatdoggy's Avatar
R/C Tech Charter Subscriber
AdR|aN - Do you have any access to a brushless motor? Also I'm not sure if you've ever run a johnson 540 but you could hit 20 minutes for runtime with one 3300 pack and they will only be a bit slower then stock if geared correctely(very high in most cases, like 5:1). Also they always run hot no matter what so you can really push them(if your track is flowing it may work). Also use stick packs with deans for quicker pit stops.
fatdoggy is offline   Reply With Quote
Old 05-28-2004, 12:03 PM   #1547
AdR|aN's Avatar
Send a message via ICQ to AdR|aN
hiya fatdoggy.
Thanks for the input.
Nope. The race doesnt allow for brushless. If they do, i wouldnt worry so much.
I was thinking about using Johnson/Mabuchi 540 motor.
But how many packs before i change a motor?
I havent tried a 540 motor yet, hopefully will try soon before the race.
Thanks man.
AdR|aN is offline   Reply With Quote
Old 05-28-2004, 12:33 PM   #1548
fatdoggy's Avatar
You might be able to finish the race on one motor. They get so hot that you'd need gloves to change it anyway. To run them in drop them in soapy water at 3v for a minute or two. Clean with motor spray and oil the bushings. During pit stops blasting the comm with motor spray will clean it a little, just a short squirt will do. I'd suggest you do some testing with one just to make sure it'd meet your needs, gearing correctely is critical for these motors and if your off your car will be slow. These motors have crap all torque so corner speed is also critical. If your track is tight the johnson 540 may not work very well...
Old 05-28-2004, 01:44 PM   #1549
personally i use a fantom team stoc i have so much power through the infield using 32/68 and still have good life and low comm wearing. i ran 9 runs and all ive done is change brushes.
rc_1uk is offline   Reply With Quote
Old 05-29-2004, 08:08 PM   #1550
fatdoggy's Avatar
.... did some more testing today. I ran the 4505 brushes for a second run with the purple/purple springs and they killed the comm very quickly and power wasn't very good. Then I dropped in the putnam greens with a fresh comm. Dam they are friggin awsome, unreal the difference. More punch, more top end but at the end of the run the excessive drag of the purple springs made the motor die a little. I dropped on a red negative spring and the motor ran better at the end of the run. I tried a green negative spring with the purple positive but it jumped(sort of hanging brush effect) on the straight and when I punched it hard out the corners. The putnam green brushes are hard on the comm but after 5 runs they are still in good condition. The serrations last ages, after 5 runs I still have serrations over the full face of the brushes. Motor temp and batt temp was higher after the runs but not too bad.
My final monster racing setup for now, Putnam green+/green- and for springs, purple+/red-. I'll do some more testing with putnam blue brushes in the next few weeks.
Old 05-30-2004, 07:17 AM   #1551
Send a message via AIM to R/C Anonymous
fatdoggy, just put the blue on the neg. side... helps with comm wear a touch and i feel its pretty much the same performance as the green green brush on the track
Geoff C.
R/C Anonymous is offline   Reply With Quote
Old 05-30-2004, 07:38 AM   #1552
Default Endurance race
AdR|aN - over on Big Jims forum there was a comment about using Trinitys Street Spec brushes (with the striped shunts) for an endurance race. They last forever and give pretty good power.
tadmj is offline   Reply With Quote
Old 05-30-2004, 02:14 PM   #1553
fatdoggy's Avatar
Thanks, I'll try out green/blue next time I go to the track. Has anybody run blue/blue before?
Old 05-30-2004, 02:18 PM   #1554
Brian McGreevy's Avatar
Send a message via AIM to Brian McGreevy Send a message via Yahoo to Brian McGreevy
Fatdoggy,
Try a Hurricane Gold brush or Paradigm 2152.
You'll like them.
USVTA Member #211
Support Formula SAE - get kids into engineering!
http://motorsports.illinois.edu/
Brian McGreevy is offline   Reply With Quote
Old 05-30-2004, 02:51 PM   #1555
fatdoggy's Avatar
Brian McGreevy - Have you tried the new paradigm 21582 *magic brush*? Interesting that it has slotted face.
I'll try the Golds and the 2152's in a few weeks, probabley wait for the 21582's to come out and order a pair or two of them at the same time.
Old 05-30-2004, 04:33 PM   #1556
I haven't gotten to test the 2158 yet only because we're trying new things with it still, but it's nearly finished.
You can get the 2158 in any brush cut you like, standard it is full face.
I'd get the standard fullface 2158's, not the slotted 21582's.
USVTA Member #211
Old 05-30-2004, 10:21 PM   #1557
fatdoggy's Avatar
O ok cool, I thought it only came slotted, I read the number wrong on the front page.
Old 05-31-2004, 12:18 AM   #1558
Fatdoggy,
Might think about trying a Binary stock. Geared right, a decent binary will beat a decent monster any day...that's what I've seen even on very, very tight/technical indoor layouts.
USVTA Member #211
Old 05-31-2004, 01:52 AM   #1559
fatdoggy's Avatar
I ran against a friend who had a binary over the weekend(must of had 8 runs on it) and there really wasn't too much of a difference. I had more top end but in the infield we were pretty much equal. If he had cut his comm and dropped in some decient brushes I'm sure he would have out powered me. Once I've got my monster at peak performance I'll be try another motor, probably the binary stock or the roar legal version.
Old 05-31-2004, 02:01 AM   #1560
Talking Stock schmock a real stock motor is....
A Mabuchi 540 in NZ you guys would have to run in Mod.
Mabuchi540 is offline   Reply With Quote
19T Motor Forum Korey Harbke Electric On-Road 550 04-11-2009 08:27 AM
Stock motor sale !!!!CO27,P2k Pro, Monsters stock Marcos.J R/C Items: For Sale/Trade 36 06-27-2006 06:26 AM
Mod Motor forum Taz_S Electric On-Road 58 11-28-2003 12:58 AM
Stock Motor Forum JLMG1971 Electric On-Road 2 10-22-2002 03:07 AM
Stock Motor forum Taz_S Electric On-Road 62 09-14-2001 12:32 PM
