Old 05-19-2004, 10:33 PM   #1501
burbs's Avatar
Send a message via AIM to burbs Send a message via Yahoo to burbs
black kat.. how about askipping a week of racing and using the money to get a motor.. if u need one that bad does it pay to run anyway??? save up... sometimes it is what u have to do...
burbs is offline   Reply With Quote
Old 05-23-2004, 07:25 PM   #1502
JDXray's Avatar
Send a message via AIM to JDXray
What are some good Spring/Brush setups for a GM3.
JDXray is offline   Reply With Quote
Old 05-23-2004, 08:32 PM   #1503
mafiaracers's Avatar
Trader Rating: 22 (100%+)
Send a message via AIM to mafiaracers Send a message via MSN to mafiaracers
I've got two setups for all my motors.
Conservative club racing:
-very low silver, (copper shunts) on negative with orion green spring....full face, serated
-medium silver, (copper/silver mix shunt) on posative with orion red spring.....full face serated
"Big Race"....all bal!s out setup:
-highest silver possible on negative with trinity black spring
-highest silver possible on posative with trinity purple spring
- posative brush is serated with hole in face a little left of center
-negative brush is full face with very slight advance timing
mafiaracers is offline   Reply With Quote
Old 05-23-2004, 09:19 PM   #1504
I rarely ever get a CHANCE to race...of course I'm gonna take it..ANYTHING beats sitting around my house with NOTHING to do.
Plus, I don't make enough in a week to get a motor if I save it all up...plus I gotta eat when I gotta eat
The Black Kat is offline   Reply With Quote
Old 05-23-2004, 09:28 PM   #1505
Suspended
Trader Rating: 28 (100%+)
daniel,
What are you gearing your monster at for Sheldons?I will help you get your car up to speed with a monster,no problem.
racenut123 is offline   Reply With Quote
Old 05-23-2004, 09:32 PM   #1506
Originally posted by KilRuf
It's a monster can and endbell with a drill balanced binary arm. 4 less laminates than the monster stock.
Isnt this considered a short stack arm ? Less laminates equals less wire length overall not making it a true 27 turn stock motor, isnt this correct ? Hence the higher rpm.
nickcacc is offline   Reply With Quote
Old 05-23-2004, 10:34 PM   #1507
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
It is the same height, you just have more space between the 2 lamination segments. Meaning they removed them from the middle.
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 05-23-2004, 10:38 PM   #1508
Ahhhh....I see...Thanks
Old 05-24-2004, 08:45 AM   #1509
Originally posted by racenut123
daniel,
25/72 in the Evo3....
If I gear it any higher I'll burn it up (its already running hot & has no punch)
If I gear it any lower I'll get NO top end
Pretty bad predicament huh?
What would putting a Monster arm in a Core can do? Have you heard about anyone doing that?
Old 05-24-2004, 09:28 AM   #1510
fatdoggy's Avatar
R/C Tech Charter Subscriber
The Black Kat - You may have overheated it on too many times and hurt the magnets. Try a 25 rollout(medium indoor carpet track) and go up teeth if you don't have enough rpm and down if you don't have enough torque. Rollout is a personal thing, everybody drives differentely so everybody requires a different rollout. Smooth driving = higher rollout. Aggressive driving = lower rollout.
Rollout is how far you car moves per 1 revolution of the motor.
Rollout = (Tire diameter x 3.14) / Overall gear ratio(final drive ratio)
fatdoggy is offline   Reply With Quote
Old 05-24-2004, 11:29 AM   #1511
Thanks Doggy...I was beggining to wonder what rollout means
I probably killed the magnets...Maybe I'll try putting this comm into a newer monster can & see how it works...I probably abused that motor sometime in my novice-ness (15, 13 min runs in a row probably didn't help) Maybe the motor going out one day was my fault...LOL
Sorry, I don't remember these kinda things....
I'll be racing primarily outdoor for a while....what would be a good rollout for those conditions? I'm smooth yet agressive...lets try some middle of the road settings
Old 05-24-2004, 11:48 AM   #1512
JDXray's Avatar
what pinion gear are people running with there monster motor? 100 tooth Spur gear.
Old 05-24-2004, 11:57 AM   #1513
fatdoggy's Avatar
You'll have to play around with gearing at the track but for a medium-small I'd start with a (23-25) and for a large track I'd start with a (26-30+) rollout. Always try a low rollout and then add teeth to the pinion one at a time. Run half a pack through practice at race pace and then pull over to check motor temp to make sure you motor isn't too hot. As long as your motor is kept in good condition it shouldn't come off screaming hot after a run(medium-hot is fine).
I run red/green springs and 767's. If you find you really have crap all torque on the medium-small track you could try dropping a red spring on the neg instead of green or a purple+/red- combo. For large tracks(flowing) rpm rules so a red/green or red/red combo may work better then the purple/red.
Old 05-24-2004, 12:02 PM   #1514
JDXray's Avatar
thanks fatdoggy. Just need to cut my comm and instal those 767. Then i will do a motor-run in. What amps should i run it at?
Old 05-24-2004, 12:14 PM   #1515
fatdoggy's Avatar
JDXray - Those (23-25) and (26-30) were rollouts not pinion gears. Run in your motor at 2-3v till both brushes have wear across the full face of the brush.
19T Motor Forum Korey Harbke Electric On-Road 550 04-11-2009 08:27 AM
Stock motor sale !!!!CO27,P2k Pro, Monsters stock Marcos.J R/C Items: For Sale/Trade 36 06-27-2006 06:26 AM
Mod Motor forum Taz_S Electric On-Road 58 11-28-2003 12:58 AM
Stock Motor Forum JLMG1971 Electric On-Road 2 10-22-2002 03:07 AM
Stock Motor forum Taz_S Electric On-Road 62 09-14-2001 12:32 PM
