Old 08-05-2005, 04:09 PM   #31
Originally Posted by Itchy
PHP Code:
I was led to believe the Nosram International was a great speedy not unlimited in turns but it's solid as a rock!
Dont get me wrong, i dont even know that particular speedo! What i meant was that u should be carefull since it has history...
Also, try to be carefull when u ran a motor close to ure speedo limit. Gearing is crucial, and prolly the most important factor, but pay atention to ure drive train. Dirt, hair carpet and other stuf get into ure car and make life hard on motor and speedo.
Ah, and gear mesh to close can also overheat the engine.
In doubt the old thumb rule (get ure finger in the motor after running. if u cant keep it there for 5 sec, reduce ure pinion) still works.
Good luck with ure new engine!
you mean motor right?
cars.cars.cars is offline   Reply With Quote
Old 08-05-2005, 04:27 PM   #32
Sorry m8!
Im not english native. In portuguese you use the same word, something like "electric engine" and "combustion engine". I forgot. Sorry for my bad english!
Off course, i meant motor
i meant: "Ah, and gear mesh to close can also overheat the MOTOR"
Itchy is offline   Reply With Quote
Old 08-05-2005, 06:24 PM   #33
ok sorry
Old 08-05-2005, 06:25 PM   #34
what wheels and gear ratios would you use for the Associated Reedy MVP Stock Plus Rebuildable Motor
and what wheels and gear ratios would you use for the Epic ROAR Rebuildable Stock Pro Motor
(simple terms please new at this electric thing.) Thank you
Old 08-05-2005, 07:45 PM   #35
Send a message via AIM to BONZAIII Send a message via Yahoo to BONZAIII
What are you going to do with the car?Race or play?Either way gear it so the motor doesn't get too hot.If you can temp it with a temp gun keep it around 160-180 farenheit.To make sure your not burning the motor up check it periodicly during a battery pack about 4 or 5 times to make sure it's not.Once you get the gearing right then check it after each run.The more free the car is the bigger the pinion you can run.If the car is too tight meaning not free or something is binding the rotation of the drive train up then the smaller the pinion you will have to run.I only race my car and the track I race on is 100-120ft in length and 50-60ft in width.I normally run a final drive ratio of 6.49 with an EA Motorsports monster based stock motor.My tires are RP36's premounts and I run on asphalt.My motor temp stays within 160-180.
BONZAIII is offline   Reply With Quote
Old 08-05-2005, 09:06 PM   #36
i know my gearing is pushing it...i use the stock gearing with a 17t double quad magnet and damn does that thing get hot, but it doesnt get tooooo hot its still reasonable. i have a final ratio of like 6.42 i believe, but damn does this thing pull off the corners =)
Illusionist435 is offline   Reply With Quote
Old 08-05-2005, 09:44 PM   #37
how do u get the gear ratio
Old 08-06-2005, 02:20 AM   #38
Team Duratrax's Avatar
Send a message via MSN to Team Duratrax
www.gearchart.com
Sean
Team Duratrax is offline   Reply With Quote
Old 08-06-2005, 11:40 AM   #39
thanks. sort of helped but i still dont know what pinion and spur gear to use
Old 08-06-2005, 11:41 AM   #40
Sorry I didn't give you the equation.
Spur divided by pinion times internal ratio of your car
example My spur is 84 my pinion is 22 my internal dive ratio is 1.7
so 84/22=3.818x1.7=6.49
My motors stay around 160-180 for the track we race on.
Old 08-06-2005, 11:52 AM   #41
how do u know what ur internal drive ration is
and does it tell u with the motor what gear ratio you should be using
Old 08-06-2005, 12:02 PM   #42
also are the EPIC ROAR stock rebuildable pro stock motor and the Associated Reedy MVP Stock Plus Rebuildable Motor good. just wondering if they are worthy of buying.
Old 08-06-2005, 12:13 PM   #43
What car do you have?I run an XRAY FK05 it has a stock ratio of 1.7.My T1R has a stock ratio of 2.125.your internal ratio is the eternal ratio of yout transmission or for like the XRAY's it's the diff gear divided by the layshaft gears.I don't know what the other ratios are for other cars but you could look on here in other forums that discuss different makers and post in there for the ratios.
No it doesn't tell you what ratio to run on the motors.I would ask at your local track or local hobby store for recommended ratios.
Old 08-06-2005, 12:20 PM   #44
I don't recall if you were going to race or just play with the car.But I have not run any of those motors.I currently now run EA Motorsports monster based motors and batteries.I am still fairly new to racing so I don't have alot of experience with all the different motors.EA Motorsports has in my opinion excellent service and turn around on thier product and questions concerning thier product.Not to mention these are the best motors to date that I have ever run.So it's up to what your doing.Just playing I'd say yes racing I'm not sure.
Old 08-06-2005, 01:40 PM   #45
i like my reedy motors, but thats just my opinion as for the other one i dunno either i really havnt looked at it that much...
Motor Question RoseTuned Electric On-Road 5 09-27-2007 12:50 PM
XXX-NT motor question Rookie01 Nitro Off-Road 12 06-26-2007 03:01 AM
Motor+ESC question SPO Electric On-Road 2 08-29-2006 06:29 PM
Motor fan question ChadCapece Electric On-Road 7 04-07-2005 11:09 AM
question about motor for ipc esc mf2rcr Electric Off-Road 2 08-11-2004 04:22 AM
