Hara's charge rate?
14.85 amps with a .9mv cutoff
and he only uses them once.
Thats what I was told
Here is Hara's setup sheet for his charger:
http://www.teamorion.com/faq/advantage_gp3700_hara.pdf
14.85 amps? Yeah, right! And I'm sure he's been scarred several times due to exploding batteries.
Originally Posted by Rookie Solara
What charger has the option of charging 14.85 amps...? That charger should be named "EXPLODE" or "FIREWORK"............
The value of the charge current can be set up to a maximum of 19.9 amps at this time, but the TURBO35 will only allow you to run a maximum of 12.0 amps when you push the (START) button.
Originally Posted by jamescam
Right out of my CE Turbo 35 manual...
Originally Posted by jeffb
Yeah, let's all just go back to the old REEDY charge cord! ha ha ha.
