Old 08-04-2005, 11:49 AM   #16
Jack Smash's Avatar
Trader Rating: 29 (100%+)
I actually have a charge cord sitting here on my desk
Kyosho / Orion / Amain.com / Protek / MIP /
Jack Smash is offline   Reply With Quote
Old 08-04-2005, 05:30 PM   #17
PitCrew's Avatar
His charge sheet says something like
GP3700
5 cells
4000 somthing mah
What class is this for? And whats with that capacity. Take a look I forgot now exactly what it was.
PitCrew is offline   Reply With Quote
Old 08-04-2005, 05:34 PM   #18
ChadCapece's Avatar
It does say 5 cells.
ChadCapece is offline   Reply With Quote
Old 08-04-2005, 05:35 PM   #19
burbs's Avatar
Send a message via AIM to burbs Send a message via Yahoo to burbs
3300 cells can handle a high charge rate.. i wouldnt recomend it every run, but a fewtimes yes.. I have charged at 10-12 amps a few times... mostly from starting a pack late... and the packa re fine..
At the last paved oval nats i was at, i saw some of the faster guys charging there packs with two turbo 30 chargers.. Yes two.. each charger was set at 8 amps, so thats a 16 amp charge.. The purpose for it is up front during the run, you will have rip like you have never seen.. If hara does it one time per pack, i doubt a pack ever exploded.. packs usually explode from continuous beating.. but it is possible
burbs is offline   Reply With Quote
Old 08-04-2005, 05:35 PM   #20
ChadCapece's Avatar
Why would Hara charge at 14+ amps? Wouln't that make finishing a mod race near impossible?
Old 08-04-2005, 05:42 PM   #21
Send a message via AIM to micros_rock
I'm pretty sure he doesn't charge at 14A. Team Orion's website posts updates to his charge setups.
micros_rock is offline   Reply With Quote
Old 08-04-2005, 05:42 PM   #22
josh69162's Avatar
Send a message via AIM to josh69162
Who knows... But I doubt he'd be able to touch his batteries. So I guess the real question is- How does he get his batteries in his car?
Originally Posted by IMPACTPLAYR
seriously... charging your batts at the same rate as the pros, throwing your batts out after 1 run, using the same equiptment as them, drinking the same soda they enjoy, or tiing your shoes like they do..... it won't make you as fast as they are....
Just because I'm a little curious doesn't mean I'm gonna go straight out and start charging at his amps, using their brand equipment. But drinking the soda he likes does sound like it might make me faster...
-Josh
josh69162 is offline   Reply With Quote
Old 08-04-2005, 05:49 PM   #23
Send a message via ICQ to v0rtex Send a message via AIM to v0rtex Send a message via MSN to v0rtex
I think he was just having a dig
To the original poster, it doesnt particularly matter what charge rate the 'pros' use - it wont make you any faster as a driver.
Your best bet is to learn exactly what different charge rates do for different types of battery and different types of racing - then put this knowledge into practice by coming up with your own battery preperation ritual. You'll be a better racer by understanding it, and this is one of the reasons pro's are pro's - they didnt get to the top by knowing thier rival's charge rate, thats for sure
v0rtex is offline   Reply With Quote
Old 08-04-2005, 06:03 PM   #24
josh69162's Avatar
Again- I know that. I was just curious since he may get packs by the truck load. I thought he may go through them quicker since he gets whatever he wants...
-Josh
Old 08-04-2005, 06:08 PM   #25
No Dramas He probly does churn through the packs quicker than the average racer, probably gets new packs each month or even quicker when a big race comes along
Old 08-04-2005, 06:44 PM   #26
josh69162's Avatar
I hope that day comes on my calendar. It would be sooooo sweet!
-Josh
Old 08-04-2005, 07:16 PM   #27
Rob Phillips's Avatar
hara's charging profile can be found at nexusracing.net. he uses the much more ctx. check it out hara's profile
Team Durango | TrakPower | DE Racing | Futaba | Restricted Paint Worx
Velocity R/C Magazine - vrcmag.com
Rob Phillips is offline   Reply With Quote
Old 08-04-2005, 07:22 PM   #28
josh69162's Avatar
From the charge set ups I've seen, it seems he uses step charging all the time. What benefits does it have over linear charging. And flex charging? Does it gradually change the charge rate?
-Josh
Old 08-04-2005, 07:30 PM   #29
Nexus Racing's Avatar
Rob,
Hara actually no longer uses the MuchMore CM due to his contractual obligations to orion. Even still, that is the profile he used at the DHI cup with his Cell Master before he switched.
NEXUSRACING.com
Nexus Racing is offline   Reply With Quote
Old 08-04-2005, 07:59 PM   #30
I wasn't sure that was entirely true. I guess it is.
Charge rate questions jimmie48fromRI Electric Off-Road 5 04-13-2007 04:17 PM
Charge rate question? jimmie48fromRI R/C Tech Site Forum 1 04-13-2007 03:13 PM
ICE charge rate tc3blue Electric On-Road 7 04-20-2005 02:15 PM
charge rate measurements The_Gaz Electric On-Road 1 06-10-2004 01:32 AM
charge rate/time nitrosaurus Rookie Zone 10 12-25-2003 11:56 PM
