motor heat sinks & fans >
Old 03-09-2014, 06:01 PM
Default motor heat sinks & fans
ok whats the best...or what works and what doesnt?
should i just run a fan or sink and fan?
how do you okk them up?
any info would be great
TeamThibault is offline
Old 03-09-2014, 06:11 PM
on my scale spec car i run a fan. on my f1 i do not run either but may start running a heat sink.
dragonracing is offline
Old 03-09-2014, 07:05 PM
Odin544's Avatar
Trader Rating: 93 (100%+)
Heat sinks are not very efficient at transferring heat away from the motor. For TC just put a fan on the chassis or on a mount to the rear of the motor blowing air onto the motor.
Odin544 is offline
Old 03-09-2014, 09:41 PM
Suspended
Both of them are works. Use fans if you want heat spill out quickly, or you can use a heat sink. If your vehicle produce heat quick and large, get a decent fan will be a better choice.
davidwills is offline
Old 03-10-2014, 09:26 AM
dan_vector's Avatar
Trader Rating: 27 (100%+)
Just a 40mm fan mounted behind the motor blowing air onto the motor with a gap of 5-10mm. I use Ride servo tape to stick the fan down to the chassis as it's really strong. Heat sinks are not needed with today's brushless motors.
dan_vector is offline
Old 03-10-2014, 09:35 AM
we still run silver cans in our gt class and was thinking about them as well.
so for 17.5 just a fan would work?
Old 03-10-2014, 09:50 AM
theproffesor's Avatar
Trader Rating: 58 (100%+)
Get an r1 fan or a superior hobbies F5. Bothbof those work great.
theproffesor is offline
Old 03-10-2014, 09:52 AM
SteveM's Avatar
Trader Rating: 148 (100%+)
I have a heat sink and a fan on my Mi5 sedan.
SteveM is offline
Old 03-11-2014, 10:13 AM
Conrad's Avatar
If the fan is on the rear of the motor it should be blowing away from the motor, extraction is far more effecient. The contact between the motor and heatsink will always be bad compared to PC heatsinks but the heat will still move through to the heatsink, the heatsink greatly increases your surface area which is the part you really want to cool to see big drops in temp. The Nosram is one of the best designs on the market but it ain't cheap.
Conrad is offline
