Old 03-09-2014, 01:14 PM   #1
Default TORO TS 120A ESC
Hello,
I've got a question about the TORO TS 120A ESC..
Today was the first time trying this ESC and after 4 mins the esc starts beeping.
Gas/reverse won't work. Steering does work!
When i check my lipo it's still 7.75v. (Nano-tech 5300 60-120c)
I'm using a Hobbywing V10 4.5T.
Motor and ESC are not getting hot.
Also now i can't seem to switch off the esc with the button anymore. Button is still working cause i can calibirate it (gas/brake/nutral)
Could anyone help? I'm clueless at the moment
Lyrix is offline   Reply With Quote
Old 03-09-2014, 09:56 PM   #2
jeff jenkins's Avatar
Trader Rating: 77 (100%+)
Double check your lipo cutoff voltage on the ESC via the programming box or with your phone via blue tooth. I have been running mine now for a few months now in mod tc with zero issues and love it. But you could also have an ESC issue because of the on off not working but it might have lost the neutral point as well I would change your neutral range in the ESC to try and match your transmitter better. Also these escs are running the same software as the hobbywing v3.1 escs so you can look at there thread for troubleshooting advice as well.
Maclan Racing Products-Bellgate Distributions-PR Racing- Prospeed
jeff jenkins is offline   Reply With Quote
Old 03-10-2014, 02:09 AM   #3
mcdomdom's Avatar
Hi guys,
I'm looking for a New ESC and the Toro TS120 is one possibility!
But i found nowwhere if the ESC got a blinky Zero boost Mode!
Can somone help me?
Thank you guys and greetings from Germany
Dominik
VBC Wildfire D06, LRP SPX Zero, Thunder Power 13,5T, Reedy batteries!!!
mcdomdom is offline   Reply With Quote
Old 03-10-2014, 05:31 AM   #4
Thank you! I will have to wait then since my programming box is on the way. Will let you know when i get it and checked all the settings!
Old 03-10-2014, 06:47 AM   #5
Originally Posted by mcdomdom View Post
Hi guys,
Can somone help me?
Dominik
Yes the ESC has blinky mode! Its a great ESC to have. If you are located here in the usa get ahold of rctech member beaker151 he is a distributor for these ESC'S
Old 03-10-2014, 07:00 AM   #6
Hello to all. If you have interest in getting one of the Toro TS120A esc's please contact me directly via email at [email protected].
Mr Jenkins has been spot on with his info so hopefully we can do our best to provide support and answer any questions.
Beaker151 is offline   Reply With Quote
