R1 Brushless Motors (Roar approved) 17.5,21.5 & 13.5
#406
I just installed mine but in my WGT. I was told that the timing sweet spot range was in the 40* mark. Gearing you will have to figure out on your own. Start with what other people are gearing at in 12th scale 13.5 at your track. I test mine on Sunday so I will report back after that.
#407
I hope they told you there is a big difference between the 40* mark on the can and 40* of overall timing.
If you're running the motor on the 40* mark on the can, your motor will get stupid hot. That's like the equivalent to running 70* degrees of overall timing.
You want to be running 40* overall timing, you're probably looking at 0~10* on the can.
#408
#409
Yup. According to a Motolizer, the average timing at 0* physical timing amount to 31* on the Motolizer. So this sounds spot on.
#410
#412
I have measured both regular and ultra premium v7 on my motolyser: both are about 30 at can timing 0
#414
is this the motor you are talking about? this is the V9 motor they are talking about.
#415
My v9 came set at 30 on the can. Should I just leave it there?
#416
V9 13.5 1/12 small technical track 79 roll 41-45 timing.
On bigger tracks you can go as high as 84 roll Depending on the size of the track
don't use temps to gauge gearing or timing, base it on Punch & fade towards the end of the run, If its not fading much its possible you are not pushing enough.
#417
R1 ultra premium 13.5 gearing help
track is aprox. 60meter straight technical track.
#418
#419
#420
