Old 08-03-2005, 12:37 AM   #1
acutts's Avatar
KO Propo Help please
I currently have the following items (Helios radio, Hara Twister 2.0, KO PDS 2363 SERVO) and someone said that all the settings could be done from a PC ... however I don't know what I need to buy to connect them? Is there one adaptor that can connect all these items to a PC and play with the settings?
Any help appreciated!!!!!
acutts is offline   Reply With Quote
Old 08-03-2005, 12:54 AM   #2
danjoy25's Avatar
R/C Tech Charter Subscriber
Trader Rating: 37 (100%+)
checkout out: www.kopropo.com
it the ICS cable that you need to buy.
Awesomatix A800 & A800X/ Mugen MTX-5 / 3 Racing F113 / Kyosho RB5 / Kyosho Mini-Z
danjoy25 is offline   Reply With Quote
Old 08-03-2005, 06:28 AM   #3
acutts's Avatar
Thanks for that but there seems to be 2 differnet items and I don't know if I need them both.
61012 KO Propo PC Interface for ICS Servo VFS 1, 2, J
61003 KO Propo ICS Communication adaptor for EX10 Helios
Do I need to buy both these items? Has anyone used any of this?
Old 08-03-2005, 12:08 PM   #4
Hebiki's Avatar
Trader Rating: 26 (100%+)
acutts... Robert will jump on here and help you out. but if you want to do your VFS..and your servo (im assuming its the ICS version) the handheld adapter will work you will just need the appropriate "card" for each one. this allows the handheld adapter to be used for the servo or esc by plugging in the proper card.
you can find more info here: http://www.kopropo.com/ICS.htm
i believe you will need a different interface for each one (servo, esc, radio), meaning you need both items above robert, correct me if im wrong on that one
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 08-03-2005, 12:11 PM   #5
Myker*'s Avatar
Send a message via AIM to Myker*
hebiki, i think he wants to use his computer to do all the programming?
Tamiya Racing Factory
Myker* is offline   Reply With Quote
Old 08-03-2005, 12:14 PM   #6
Hebiki's Avatar
yup you can definitely do that. just download all the software and get all the interface cables.
im just not sure if there's a specific one for each item (esc, servo, radio) i have the esc PC Interface. thats it.
Hebiki Design Works
Old 08-03-2005, 12:16 PM   #7
Default Programmer
acutts-
To program everything with the PC you will need the ICS Value Set #61001. This includes the PC interface and the adapter for the EX-10 Helios. I beleive the current programs that are offered with this value set are the Helios, servos and VFS-2000. You can download the VFS-1 program for free from our website. This will allow you to program the radio, servos and esc.
-Robert
KO PROPO Staff is offline   Reply With Quote
Old 08-03-2005, 12:36 PM   #8
brandbrainz's Avatar
I use nearly the same equipment and tested both, the handheld and the PC version. I found programming on the PC much more usefull. You can store as many setups as you've got space on your HD. The programmer only allows 3 setups and you can't use it with your helios.
brandbrainz is offline   Reply With Quote
Old 08-03-2005, 02:06 PM   #9
stegger's Avatar
If i have thr software downloaded onmy laptop is there anybody out there in forum land who knows what the pin configeration is for the leads required to connect the Helios,servos and VFS-1?????
stegger is offline   Reply With Quote
Old 08-03-2005, 03:24 PM   #10
There is more to the cable then just the pin configuration. There are several electronic parts when you open the plug that's connected to the PC
Old 08-03-2005, 04:01 PM   #11
stegger's Avatar
They are probably resistors. can anybody post a picture???
Old 08-04-2005, 01:30 AM   #12
acutts's Avatar
Thanks for the Info guys
Old 08-04-2005, 02:41 AM   #13
Jepp:
Old 08-04-2005, 03:26 AM   #14
stegger's Avatar
BRANDBRAINZ thanx for the picture but i can't make out the spek of the micro resistors etc. Also can you post a picture of the reverse side.........
Thanks again
Old 07-30-2008, 04:55 PM   #15
djgoku's Avatar
Default bought ICS USB Adapter 4 Helios
Originally Posted by KO PROPO Staff View Post
acutts-
-Robert
Recently bought ICS USB Adapter, to progam my mini-z 2,4 and my Helios EX-10,
But Dont know what cable to use on the Helios?
Could you help me, read on the manual that I should use the "multy acces port" but the cable suplied have only 3 pins and the port has 8 wich 3 out of the 8 should I connect to?
djgoku is offline   Reply With Quote
KO PROPO BMC-VFS esc Molala3 Electric On-Road 0 04-23-2008 11:57 AM
KO PROPO VS-1 FS/FT Headshot R/C Items: For Sale/Trade 5 11-11-2007 06:16 PM
ko propo buffalobill989 R/C Items: Wanted to Buy 2 08-09-2006 05:08 AM
~F/S Ko Propo Mars R/Ko Propo VFS 2000 Pro/BMI FK05~ RandomTask R/C Items: For Sale/Trade 5 06-21-2006 10:18 PM
WTB Ko Propo VFS-1 Pro Roberto Falcon R/C Items: Wanted to Buy 5 10-22-2005 11:36 AM
