Kimbrough Servo Saver
my Servo Saver came apart when i was installing it (removing it from the servo to re line)
any tips on how to put it back together or is it nfg?
Are you sure it's not just that the insert came out? They're designed so that there's an adapter insert that goes between the saver and the servo to adapt it for the different spline counts on different servo brands. That should be easy to just pop in and out.
If you can see the spring, though.... oops.
-Mike
