Old 07-31-2005, 03:39 PM   #1
Send a message via AIM to micros_rock
Default Unglue Tires?
Just a quick question, I need to unglue my tires off the rims, what is the best way to go about doing this? Boiling them? I need to "save" the tires, don't care so much about the rims. Thanks
micros_rock is offline   Reply With Quote
Old 07-31-2005, 04:33 PM   #2
I baked some last week and it worked great. I pre-heated the oven to 325 then baked them for 12 minutes then turned off the heat and lefted them in for another 5 minutes, they came off very easy.
RCAmerica | Xray | Team Tekin | RC Paint By Sonny | P1 Brand
Monte Hess is offline   Reply With Quote
Old 08-04-2005, 12:47 PM   #3
What did you put the tires on? Cookie sheet, foil, etc? I would think the rubber might start to melt a bit?
Old 08-04-2005, 02:18 PM   #4
Mal
Registered User
Don't even try that .... Nice way to set your house on fire.
I've never tried it myself but I hear placing the tires in a covered jar with a little acetone does the trick.
Mal is offline   Reply With Quote
Old 08-04-2005, 02:22 PM   #5
Tommy Bergfeldt's Avatar
Send a message via ICQ to Tommy Bergfeldt
Around 300 degrees in the oven for 10-15 minutes does the trick. If the tires doesn't come loose easily just bake them a little more, You can use the inserts again if you like too, even the tires if you want to.
JMI Motorsport / Red Bull Racing
HB Cyclone TC - Schumacher CAT SX & Cougar SV
Advanced Electronics - Autopartner.se - Sav÷x - NorthTQ
Tommy Bergfeldt is offline   Reply With Quote
Old 08-04-2005, 03:55 PM   #6
300 degrees celcius?! wont that burn the rubber? Guess it must be Fahrenheit...
Itchy is offline   Reply With Quote
Old 08-05-2005, 03:54 PM   #7
belgianchamp's Avatar
Send a message via MSN to belgianchamp
mmmmmmm,burned rubber cookies.
belgianchamp is offline   Reply With Quote
Old 08-05-2005, 03:57 PM   #8
Pezz's Avatar
Send a message via Yahoo to Pezz
Never tried it but you can buy CA de-bonder from your LHS, that would be a nice safe way to do it. I have used de-bonder on airplane stuff for over ten years.
-B
Pezz is offline   Reply With Quote
Old 08-05-2005, 03:59 PM   #9
Ive heard from other guys to lay it in water and let it boil.
Old 08-07-2005, 03:01 AM   #10
Yes, 300 Fahrenheit, 150 C
Best way to "unglue" tires? superx421 Nitro Off-Road 24 07-19-2008 10:05 PM
Servo died. How to unglue it?????? jheimb4897 Electric On-Road 11 01-17-2008 05:57 PM
unglue tires?? lynell90 Nitro Off-Road 21 09-18-2007 08:02 AM
How to unglue..........glue? K_King Electric Off-Road 24 01-22-2007 01:36 PM
how to Unglue, sloopy glued tires? tabarism Rookie Zone 12 05-03-2005 06:37 PM
