Old 02-23-2014, 06:16 PM   #16
Rxfisher's Avatar
Trader Rating: 18 (100%+)
Default It's how I got intonthenhobby
Torment ecx chassis with Parma 55 Chevy body
I need a new hobby: 1950 Chevy Street Rod RC-image.jpg
22 Losi Buggy, HPI BLitz, ECX Torment, Duratrax Element, ten-SCTE 2.0, tekin gen1, pro4 4600, losi 8ight 3.0, orion r8 pro
Rxfisher is offline   Reply With Quote
Old 02-23-2014, 06:20 PM   #17
Rxfisher's Avatar
Default Also a 57 pick up
Mounted on HPI blitz
Old 02-23-2014, 07:08 PM   #18
I believe RJSpeed has a '53 truck
Ruger1 is offline   Reply With Quote
Old 02-28-2014, 02:14 PM   #19
bigfatslob's Avatar
Default RJ speed & Parma
I've used both RJ Speed and Parma bodies on 1/10 sedan chassis. Parmas are a bit wide and wheel base is a bit long, Some RJ Speeds are a bit short. When I get the bodies I put the clear uncut bodies over the chassis and put a sharpie to where I'll cut out the wheel arches. You can always cheat a little to help it fit better. You can then move the wheels out wider on the chassis by using 12mm hex wheel adapter/wideners. Here's a '34 Ford P.U on a Tamiya chassis and a '41 Willys on a Losi XXX-S chassis :
I used 1/10 truck tires & rims on the rear of the Willys w/ HPI LPS drift 35mm fronts so they will slip due to four wheel drive and different diameter. The P.U, has HPI vintage rims and tire w/ white wall vinyl decals.
Vintage is the way we roll : XXXS & TT01
bigfatslob is offline   Reply With Quote
Tags
abc hobby genetic, cup racer, proline body, tamiya cc-01, tamiya m-06
