Old 02-21-2014, 11:00 PM   #1
Trader Rating: 14 (100%+)
Default Kyosho gt2 E? Help!
I am running a gt2 Electric with a MM 2650 motor & esc with a 4s lipo. Spur gear is a 46 & pinion gear is a 25. I am running this setup to drag race 132ft. Car is running okay I want it to have more top end should I use a bigger pinion gear? Or what setup should I run?
Thanks for your time!
espnstang25 is offline   Reply With Quote
Old 02-22-2014, 08:52 PM   #2
reracer's Avatar
At 132 feet, that 2650kv motor is probably not up to speed yet. Try a smaller pinion with that motor, or a larger/higher power/lower KV motor(something like a 4082 Leopard motor) with the 25t pinion.
reracer is offline   Reply With Quote
