Old 07-28-2005, 06:14 PM   #1
Default Charger Question, Please Help!!!
hi,
i have a novak millenium charger. does anyone know how to lower the mv when charging???
Joe Chaplow is offline   Reply With Quote
Old 07-28-2005, 07:05 PM   #2
ALBERTO's Avatar
Trader Rating: 23 (96%+)
Send a message via AIM to ALBERTO Send a message via Yahoo to ALBERTO
if you go to teamnovak.com you can download the manual...... might help you out
try this
scroll down
still fishing
ALBERTO is offline   Reply With Quote
Old 07-29-2005, 11:33 AM   #3
try this
scroll down
thanks for your help.
Old 07-29-2005, 01:51 PM   #4
Super Moderator
Grizzbob's Avatar
If you're talking about changing the mV threshold WHILE charging, can't be done without stopping the charge & resetting it, but before you begin charging, just use the up/down buttons to scroll through the menus till you see one that says "Edit Charge", then hit the OK/Select button to go into it(same button that starts the charge cycle), & use that same button to OK every setting of the carge. And to be able to adjust the mV threshold, you have to set charge mode to NiCd Linear(not NiMh, using that mode will have the charger set the threshold on its own & can't be adjusted) & continue through the settings until you get to the voltage threshold setting & then you can change it with the up & down buttons & hit OK to confirm it, then you're ready to charge with the new settings...
Bob Seay
Tamiya TRF417, TA05v.2, TRF211XM, M-05ver.2R, XRAY X12, Associated B5m Factory Lite
Go Pokes!!!
Grizzbob is offline   Reply With Quote
Charger Question Evilstealth Electric On-Road 1 01-29-2007 03:29 AM
charger question peanutbrains Nitro On-Road 9 08-22-2005 09:34 AM
Charger question RedBullRacin Rookie Zone 5 01-16-2004 01:36 AM
indi charger question/3300mhz battery question TT_Vert Electric Off-Road 4 12-27-2003 12:46 PM
Charger Question Motorsports00 Australian Racing 33 10-13-2003 01:14 AM
