JACO tire news
Old 02-10-2007, 06:45 PM
  #586
Anthony.L's Avatar
Trader Rating: 41 (100%+)
Originally Posted by superslow
does anyone know where to get the new jaco wraps 2 stage with the spoke wheel. let me know thank you.
They are called the 26mm 2-Stage foams. Any dealer can order them, they are in stock most places including Stormer.
Do you understand the difference, or are you just wanting the spoked wheel?
Anthony.L is offline
Old 02-10-2007, 08:46 PM
  #587
superslow's Avatar
thanks, i believe they are just lighter for rotating mass and therefore take off quicker. or maybe grip better because of the inner foam
superslow is offline
Old 02-10-2007, 10:24 PM
  #588
Switch Blade's Avatar
jaco now has their yellow 12th scale tires for sale...well maybe they have been for a while, but i have just started to see them recently
Switch Blade is offline
Old 02-12-2007, 10:26 AM
  #589
timmay70's Avatar
www.teamkwik.com
timmay70 is offline
Old 02-13-2007, 11:46 PM
  #590
Does anyone have any suggestions on the type of glue to use around the edge of the tire where the foam is glued to the plastic rim? I have problems once in a while with the foam pulling away from the plastic. I have used medium gap CA it works ok but hard to get it exactly where I want it and it seems to crack on the foam sidewall. I was just wondering if there was other types of glue anyone has tried or maybe a different thickness of CA. Thanks for any help.
Kev
Killerkevin is offline
Old 02-13-2007, 11:58 PM
  #591
TeamButter's Avatar
Kev
Can't go wrong with Losi glue.......
TeamButter is offline
Old 02-14-2007, 12:16 AM
  #592
syndr0me's Avatar
Trader Rating: 32 (100%+)
Kev
I believe you're changing the handling characteristics by gluing the sides of the tires, and not just reenforcing the foam's bond to the rim. As I understand it, gluing them will decrease the side bite of the tire. It seems to be popular at high-traction tracks. The very thin CA seems to work the best.
syndr0me is offline
Old 02-14-2007, 06:43 AM
  #593
timmay70's Avatar
There's always contact adhesive for after the foam tears from the glued rim...
timmay70 is offline
Old 02-14-2007, 07:33 AM
  #594
Yah thats more of my problem. The foam starts to tear away from the rim and just wondered what the best glue was to re-glue it and or stop it from doing that in the first place. It is mainly the rear tires that I have problems with.
Old 02-14-2007, 10:29 AM
  #595
mtveten's Avatar
Trader Rating: 28 (100%+)
Contact cement, rubber cement and fender mender all work well to reglue the foam to the rim when it starts peel. I wouldn't recommend using CA since it will harden the foam and change its handling characteristics.
Mark
mtveten is offline
Old 02-14-2007, 04:09 PM
  #596
Use ca, but only glue up to the middle glue seam! You can do more of the fronts if needed to help if you are traction rolling.
walterhenderson is offline
Old 02-15-2007, 11:57 AM
  #597
Are the part numbers mixed up on Jacos site or everywhere else? On Jacos site it says 4160 is a dub pink front and on the ebay sites and stormer it says 4160 is a dub pink/orange.
The8BitHero is offline
Old 02-15-2007, 04:53 PM
  #598
Trader Rating: 21 (100%+)
4160- dp/orange
4156- double pink
Brian L is offline
Old 02-15-2007, 04:54 PM
  #599
Company Representative
Trader Rating: 15 (100%+)
Thanks for pointing that out, We will get it changed asap.
You are correct, it should be JAC4160 Double Pink/Orange Front.
With the matching rear being the JAC4156 Double Pink Rear.
Korgae is offline
Old 02-15-2007, 06:38 PM
  #600
So, is the 26mm the set-up for everyone? Or is the 28mm still the popular choice?
Juan Aveytia is offline
