Old 02-11-2014, 07:10 PM   #1
Unhappy over heating ORCA TX17.5
Here is my problem: My 17.5 Orca TX heats up all the time,I drive a Mi5 with a 70 spur in blinky mode our track as 14 turn an a 85 foot back strech. So far I have tried pinions from 30to 34 with high timing and low. My ECS is a Reventon pro1.1
Thanks forthe help.
srobidoux is offline   Reply With Quote
Old 02-11-2014, 07:15 PM   #2
Trader Rating: 27 (100%+)
Thanks forthe help.
Start with your final around 4.0-4.2 and temp it from there. Timing at 20. If you want to get closer on your ratios, go with 64pitch gears.
JoeyE is offline   Reply With Quote
Old 02-11-2014, 07:16 PM   #3
Jerz616's Avatar
Trader Rating: 49 (100%+)
Thanks forthe help.
When you say heats up how hot? They can take some heat and be fine. I would say 160 or so is ok. There could be many things that might cause it. Check for binging ind bearings or the drive train first off.
Ryan Gracey
XRAY T4'14/ORCA VXX/ORCA TX 5.0
XRAY XB8'14
Jerz616 is offline   Reply With Quote
Old 02-11-2014, 07:17 PM   #4
rc car guy's Avatar
Thanks forthe help.
Try a 96-100 with a 4.0 final drive make sure your car is free oil the bearings in your car make sure its free try a timing of max
I drive a 6.2 with a revention 1.1 and an orca 17.5 tx with a superior hobbies f5 fan what tires are your running do you have too much traction I was having the same issue it was between the tires and having too much traction and needed a good fan my track is 60-36 we have a rather long straight probably 96 feet long or so
rc car guy is offline   Reply With Quote
Old 02-11-2014, 07:24 PM   #5
edhchoe's Avatar
Trader Rating: 41 (100%+)
That FDR checks out to be 3.7-4.2 which is alright.
I have mine at 1mm past the highest mark. And FDR at 3.72. Our track is more open than yours though. 10-12 turns.
edhchoe is offline   Reply With Quote
Old 02-11-2014, 07:28 PM   #6
Geezatec's Avatar
70t pinion! you going for top speed! 14 turn track you'll find it better with a smaller pinion. cut it to 1/2 35T. You'll find coming off corner better, and heat of the motor comes down. experiment! Half the straight you'll see at its top speed, instead of it climbing for speed.
Geezatec is offline   Reply With Quote
Old 02-12-2014, 03:08 PM   #7
xrayracer1's Avatar
Go to a smaller pinion/bigger spur, and also check your driveline. Make sure it moves free without binding.
xrayracer1 is offline   Reply With Quote
Old 02-12-2014, 08:11 PM   #8
Thanks for all the replies I will try some of your sugestion.
P.S. there is no binding in the drivetrain, with the same set up an my friends Tekin Gen2 I manage laps one second faster. Its a new motor and i would like to make it work for me.
Old 02-12-2014, 08:22 PM   #9
EDWARD2003's Avatar
Do you have a temperature gun to check the motor temps? You're best bet it to buy one and monitor the motor temps for each adjustment you make. Make sure there is a "tick" of play between the spur and pinion gear. If you have the two gears mashed together, that can cause unwanted friction which will generate motor heat.
Also, drive the car for 2 mins then temp and then adjust the gear ratio and motors timing.
Are you running any advanced timing from your Reventon Pro?
I am running the same setup with no problems at all.
EDWARD2003 is offline   Reply With Quote
Old 02-12-2014, 09:05 PM   #10
VooDooPH's Avatar
Trader Rating: 18 (100%+)
Send a message via Yahoo to VooDooPH
if you've overtemped the motor a number of times, chances are the rotor has lost its magnetism... if so, no matter how you adjust your fdr and timing the motor will still run hotter than usual...
[TRF418][TB-04Pro][FF-03Pro][M-05v2][TRF102][F-104 WGP][TT-01R TypeE]
[Cross CF-01'08][Yokomo R12][Team C TC02Evo][Team C T8E v3]
VooDooPH is offline   Reply With Quote
