Old 02-11-2014, 04:37 AM   #1
Default Scales
What scales work the best? Where is the best place to get a deal on them and does anybody just use the small kitchen food scales?
I have yet to balance my car this way and hoping it makes a difference.
Atechbh is offline   Reply With Quote
Old 02-11-2014, 06:02 AM   #2
daleburr's Avatar
Cheapo 500g jewellery scales off ebay. I use two scales and two blocks of 18mm MDF for the other 2 wheels to get them to the same height. Or buy four scales if you're feeling rich
Team Xray
RC-Timing Software - http://www.rc-timing.com
Mercedes AMG F1 - http://www.mercedes-amg-f1.com/
daleburr is offline   Reply With Quote
Old 02-11-2014, 06:36 AM   #3
sosidge's Avatar
I have four basic kitchen scales - they are sufficiently accurate for corner weighting. Also means I can corner weight buggies as 500g per wheel is too low for them.
Old 02-11-2014, 07:49 AM   #4
daleburr's Avatar
That's true, when I tried to do my buggy I wished I'd bought the 1000g versions instead!
Team Xray
Old 02-11-2014, 09:41 AM   #5
Does it handle noticeably better after scaled?
Old 02-11-2014, 09:44 AM   #6
Aaron P's Avatar
Yes, a balanced car handles noticeably better.
Aaron P is offline   Reply With Quote
Old 02-11-2014, 09:49 AM   #7
I gave up on scales for everything but getting an idea of front / rear weight. For left / right balance, I have better luck lifting with wrenches under the shock towers. And for final de-tweaking I get best results by setting droop spot-on with a droop gauge, and then using setup wheels and lifting one end of the chassis at a time and making sure the wheels lift at the same time.
EDIT: And yes, a left / right balanced and detweaked car handles muuuch better. Front / rear balance is a tuning aid. In my experience, more weight forward gives more on-power steering and more resistance to traction roll on carpet, at the cost of less corner entry steering and more heat in the front tires. More weight to the rear gives a smoother car with more corner entry and mid steering, and puts more heat into the rear tires, and can work better on asphalt.
-Mike
Old 02-11-2014, 09:53 AM   #8
RazzBarlow7's Avatar
Who makes the best?
These guys:
And they're only $800.00!
My wallet sponsors the following companies: Tekno, X-Factory, Schuur Speed, Tekin, SDRC
B4.1 (retired)
Tekno SCT410, Schuur Speed 4300KV, Tekin RX8, Reedy 7000mah
X-Factory Cubed #163, Schuur Speed 17.5, Tekin RS Gen 2, XP1015, Reedy 4100 Shorty
UNDER CONSTRUCTION: X-Factory SCX60-CF #132
RazzBarlow7 is offline   Reply With Quote
Old 02-11-2014, 08:21 PM   #9
Trader Rating: 17 (100%+)
Originally Posted by RazzBarlow7 View Post
Who makes the best?
These guys:
Holy 8888 that's just the ultimate scale setup if I ever saw one! It give you the weight distribution percentages too! Incedible machining. Yeah they're worth every penny. But I don't think you NEED to spend this much for a set of scales.
I've done pretty good with a 2-scale board setup from lefthander-rc.com
Hobbytalk trader rating:http://www.hobbytalk.com/bbs1/itrader.php?u=13594
Outlaw 44 is offline   Reply With Quote
Old 02-11-2014, 09:00 PM   #10
SWTour's Avatar
I like the little ones from Harbor Freight - they seem to do fine - and really don't need a "Scale Table" if you are on a flat surface.
http://www.harborfreight.com/hand-to...ale-93543.html
Mine are a little different than these, but were about this price.
Joe Myers
R/C Racing since 1985 ~ Santa Maria, CA (Central Coast)
2001-2012 - South-West Tour R/C Oval Series...will the SWT be revived?
Things are headed towards a return of the SWT Series, but for
2017 the focus will be on the Encino Velodrome (and dirt oval racing)
SWTour is online now   Reply With Quote
Old 02-11-2014, 09:37 PM   #11
dan_vector's Avatar
Trader Rating: 27 (100%+)
I use these cheapo's from RC-Mushroom. Work very well indeed.
http://www.rc-mushroom.com/product_i...-scale-p-14555
Serpent Viper 977e EVO2, Serpent Viper 988 GP, Serpent Project 4x, Serpent 811T-TE Truggy, Serpent 811e 2.1, Serpent SRX2-MH, Serpent SRX-2 RM, Serpent SRX-4, Serpent F110-SF2, Serpent F180, Serpent 748 Natrix WC, Serpent Cobra GT 3.1, Serpent SRX8, Serpent S811 2.2, Baja 5B Flux, Atomic AMZ 1/27th, Schumacher GT12 SS.
Sanwa, Ielasi Tuned Novarossi Racing Engines, Tekin, Hobbywing, Muchmore.
dan_vector is offline   Reply With Quote
Old 02-11-2014, 11:15 PM   #12
Josh-n-ya's Avatar
Trader Rating: 75 (100%+)
amazon has small scales and cheap.
Josh-n-ya is offline   Reply With Quote
Old 02-12-2014, 07:08 AM   #13
F. Mendoza's Avatar
Trader Rating: 79 (100%+)
At one time I was able to buy them for under $15 each. They were cheap scales that done the job. I sold a few sets here on RCTech. I never had complaints that they were bad or didn't work.
http://www.rctech.net/forum/r-c-item...ing-tweak.html
These here would work too as suggested by SWTour. More capacity and a bit cheaper.
http://m.harborfreight.com/1000-gram...ale-60332.html
RC America - Xray - Hudy - Gravity RC - KO Propo - Super Rad Graphics
Mr. Shookie goes home 10-06-08. Bill Levinson 4-14-15
F. Mendoza is offline   Reply With Quote
Old 02-12-2014, 07:20 AM   #14
Hobbyking
Infinity IF14
www.machheemstede.nl
..................................Youtube: https://www.youtube.com/watch?v=_-Gkh2xZcQU
Modified 4 life
Govert is offline   Reply With Quote
