Muchmore tires?
I've never tried the Muchmore tire on carpet - but the Muchmore Absolute 28s are great in cooler weather, and the 32s work really well once temps reach 75-80 degrees outdoors. Probably the most durable rubber tire I've ever used, and they offer fantastic grip.
I've never seen the need to use the 36s, as the 32s were up to the task of handing 90+ degree outdoor temps. Even on the most abrasive surfaces in 90+ degree heat, the 32s performed exceptionally well.
I'd try the 32s and 36s on the same day under the same track conditions to see what differences there are regarding performance and durability.
We run them a lot in Australia.
the new (old now released last year) rush 36 work very well an most asphalt tracks here.
even when cold ambient you can get them to work by heating.
most at my track run them nearly year round even in winter at night. 10 deg cel air temps.
Wait until you try some Jaco's from the Snowbirds batch.... dial in max dual-rate and your car might steer....
Suspended
