Old 07-26-2005, 01:03 AM   #1
Moderator
StephenSobottka's Avatar
Send a message via AIM to StephenSobottka
Default Reciever Capacitor
Alright, I was pondering about putting on a reciever capacitor to help keep voltage at the reciever during high amp draws in mod sedan. How would I go about doing this? I was thinking that I should just be able to hook it up in the wire from the speed control to the reciever. Correct me if I am wrong.
~~Stephen Sobottka~~
SMC Racing
StephenSobottka is offline   Reply With Quote
Old 07-26-2005, 01:54 AM   #2
Randy Caster's Avatar
Trader Rating: 46 (100%+)
You should just be able to put it on a regular plug for the reciever and hook it up to positive and negative.
Old 07-26-2005, 08:18 AM   #3
Nexus Racing's Avatar
Thumbs up
will it be like this?
NEXUSRACING.com
Nexus Racing is offline   Reply With Quote
Old 07-26-2005, 08:25 AM   #4
Administrator
Matt M.'s Avatar
Trader Rating: 26 (100%+)
steve
i use a novak cap...i will show it to you on friday or sat...i use one with my spektrum......
Matt M. is offline   Reply With Quote
Old 07-26-2005, 10:15 AM   #5
Moderator
Thanks for the replies guys.
Randy- That is what I was pretty sure I was going to do.
Matt- Thats exactly what I was going to use lol
SMC Racing
Old 07-26-2005, 10:21 AM   #6
ChadCapece's Avatar
Is this Kumpol?
ChadCapece is offline   Reply With Quote
Old 07-26-2005, 02:45 PM   #7
Trader Rating: 52 (100%+)
Stephan you goof ball, you run for novak!!!
just tell Charlie to get you one.LOL
Mo
Mo Denton is offline   Reply With Quote
Old 07-26-2005, 09:51 PM   #8
Moderator
Got it to work out lol, i had an extra one laying around lol
SMC Racing
Old 07-27-2005, 07:18 AM   #9
The one Spektrum is coming out with next month is 4700uf 10volts
I bought a cap last night at my local electronics store for $5.10
it's 4700uf and 16volts. They didnt have the 10v one but the guy there said it would be fine.
I am no electronics guru can anyone confirm if the 16v 4700cap will be fine for me to use?
erock1331 is offline   Reply With Quote
Old 07-27-2005, 08:16 AM   #10
2-Bad's Avatar
Trader Rating: 24 (100%+)
The working voltages of capís indicates its maximum it can take. Ideally if you can get a 10volt would be good (more accurate to the voltage in the circuit); however its performance difference to a 16volt would be virtually zero.
2-Bad is offline   Reply With Quote
Old 07-27-2005, 08:31 AM   #11
Sweet thanks !!
Old 07-27-2005, 09:03 AM   #12
2-Bad's Avatar
With the increase auxiliary options required from receivers these days (personal transponders, fans, etc) it seems a waste to use up one of these plugs on a filtering cap. Wouldn't it be better if it was hard wired to the pos+ neg- of the Speedie plug to the receiver? Then it's a permanent part of the speedie (where the voltage spikes/problems are created) not matter what receiver you plug it to.
Old 07-27-2005, 09:27 AM   #13
2-bad,
Say if i use my Novak GTX which already has the power cap (4700uf 10v) installed on speedo.
Am I being redundant in adding this cap to this receiver or will they serve 2 different purposes?
All I am trying to prevent is having to use a receiver pack.
With my quantum 1, it kept shutting down my spektrum reciever cause as I understand it the BEC voltage the Quantum 1 is set at is too high keep the spektrum reciever running when the voltage spikes/dips below the required amount to operate it.
so what you are saying is if i add this cap then I would have 2 caps on the GTX, the one that comes with it soldered to the battery/motor leads and then one soldered to the receiver plug leads
Old 07-27-2005, 09:47 AM   #14
2-Bad's Avatar
2-bad,
Erock.... The cap on the receiver plug is a filter for the voltages spike (under voltage protection), the one on the speedie motors is for motor spikes (to add punch). All this is good to add to your electrics...
I'm sorry if I confused the issue.... I was just thinking that it would be neater if the "voltage protection cap" was hard wired instead of using up a receiver slot to filter it from.
Old 07-27-2005, 09:49 AM   #15
2-bad
Got it, that is what I thought.
Thanks.
JR XR3i Radio Reciever, Hitec Universal Reciever, AMB rc Personal Transponder Erc R/C Items: For Sale/Trade 11 07-13-2008 01:12 PM
Hitec 625MG servos $20 Futaba PCM reciever $30 Novak reciever $20 kreidel R/C Items: For Sale/Trade 8 08-30-2007 01:43 PM
Capacitor surrealmaterial Electric On-Road 8 02-28-2007 02:09 AM
Help with capacitor please Montrealer Electric On-Road 22 01-18-2007 03:59 PM
HRS Reciever, Air. Reciever, Kinwald Radio Bag, Hakko Soldering Station, XXX-4 Parts Biscuit R/C Items: For Sale/Trade 24 08-25-2006 11:06 AM
