TRG114
Old 01-31-2014, 03:33 AM
Default TRG114
Is there nobody who knows when this kit will be placed on the market?
http://www.rc-trg.com/trg114.html
Ciao
Max
mtaddei is offline
Old 01-31-2014, 04:28 AM
idbdoug's Avatar
Trader Rating: 38 (100%+)
Ciao
Max
Check with www.reflexracing.net
They sell TRG Stuff
idbdoug
idbdoug is offline
Old 03-31-2014, 07:48 AM
no body is using this mode except here in Italy?
mtaddei is offline
Old 04-01-2014, 02:05 AM
Zedsispeho's Avatar
I have seen ONE model in France and it is the TRG 111 transformation kit (2011 version)
It is sold here with other TRG parts
http://www.asia-racing-team.com/shop...9721b7605321fb
I have not seen any more recent version except in this Italian shop which ships all over Europe:
http://f1shop24.com/shop/index.php?c...nguqpmomb613j5
Zedsispeho is offline
Old 04-01-2014, 03:02 AM
i'm racing with the trg114, and i was interested to know if somebody else in the world is using such model so that we can share our experience and set up suggestions
mtaddei is offline
Old 04-20-2014, 12:11 AM
Would this be a better chassis than the stock F104 v2 in a tight bumpy track?
speed6 is offline
Old 05-04-2014, 01:16 PM
Ciao Speed6,
sorry for my late replay, honestly i'm not able to answer your question.
I'm surprised that except here in Italy nobody in USA or somewhere else is using such model!!!
mtaddei is offline
Old 09-25-2016, 06:05 AM
G-rem's Avatar
Hi there,
can someone tell me if the front kingpin (TRG1108 in the TRG 114 manual) is the same size as 1/12 or 1/10 pan car kingpins (1/8")?
Thanks a lot for your help,
G-rem
G-rem is offline
Old 09-25-2016, 10:08 AM
The king pins are 3mm but they also have the 2 pivot balls integrated into the king pin that standard king pins don't have
have a look at f1shop24 images are on there
ntc2008 is offline
Old 09-25-2016, 11:25 AM
G-rem's Avatar
Thank you very much!
G-rem is offline
Old 09-25-2016, 06:26 PM
choisan's Avatar
I am still running the 112W on foam, later on i will run this car on runner tire. I lvoe my 112. Some people modified the Asso plastic 1/12 side bar in this car.
For the kingpin, the 2mm clip should fit. Those from 1/12 or 1/10 are not compatible.
choisan is online now
