Old 07-25-2005, 04:57 PM   #16
AdrianM's Avatar
TTT
Adrian Martinez
Old 07-25-2005, 06:35 PM   #17
gee-dub's Avatar
Originally Posted by AdrianM
... Everyone has team level batteries, two GFX's, They buy a dozen motor to find a fast one, cut and rebrush every run in every class, new tires for the main, etc. But this is why the A-Mains in Stock and 19T at every big race in the last couple of years have been full of Floridian racers.
*cough*tooscaredtostepuptomodwithcaliracers*cough*
sorry, saw the opportunity, took the shot.
good info on the motor. i have been looking to pick one up and give it a go. also sounds like this might make a great 19t truck offroad motor.
gee-dub is offline   Reply With Quote
Old 07-25-2005, 06:43 PM   #18
losi jon's Avatar
geedub---you need to bring that action to Haven on an offroad friday night.you know we are running 19t truck right?
losi jon is offline   Reply With Quote
Old 07-25-2005, 06:59 PM   #19
Team EAM
EAMotorsports's Avatar
Trader Rating: 79 (100%+)
Send a message via AIM to EAMotorsports
You could have just stuck an EAM Sticker on it and it would have been a tenth faster off the bat!!
EA
Contact Us
Team EAM, Our Facebook
Team EAM | Xray | RCAmerica | Hudy | APEX Raceway and Hobbies | RC Mission | Killer Concepts | AVID | Hobbywing.
EAMotorsports is offline   Reply With Quote
Old 07-25-2005, 07:35 PM   #20
AdrianM's Avatar
Uh...FYI, I usually race Open Mod Sedan and 1/12th 19T (Not one wants to run Mod 1/12th). Sometimes I run Open Mod Sedan and 19T Sedan. I ran 19T sedan this weekend to keep the 19T regulars humble
Adrian Martinez
Old 07-25-2005, 07:36 PM   #21
AdrianM's Avatar
EA
Some EAM batts would have made it really fly
Adrian Martinez
Old 07-25-2005, 07:42 PM   #22
Send a message via ICQ to v0rtex Send a message via AIM to v0rtex Send a message via MSN to v0rtex
AdrianM, How have you found the V2 Dynasty compared to the original plastic endbell Dynasty?
v0rtex is offline   Reply With Quote
Old 07-25-2005, 09:04 PM   #23
AdrianM's Avatar
I don't know how they compare but a few fast guys in the Florida State Series (www.fseara.org) have been running the conventional end bell Dynastys and Element 19T's. They are certainly as fast as the Reedy motor. I ordered some conventional end bell Dynastys today to test for myself.
Most of the guys here run are Reedy QM19's. My V2 Dynasty is at least as fast maybe a little faster.
The main reason for this thread was to show the V2 version could be fast. Lots of guys were knocking it at first. The release of the V2 Dynasty was just like the release of the Reedy QM19 Everybody thought the Reedy QM19 was slow until a few guys figured it out.
The way I figured out the gearing was by running it up on a Much More Motor checker at 5v. My good Reedys turn ~22.5K. The Dynasty turned ~20.5K. To reach the same wheel RPM (same top speed on the track) I calculated that I need to gear up ~5 teeth (5.0:1 final drive) I tried it ands it felt soft on the bottom so I went to the next smaller pinion (5.14:1). I basically just rolled the dice and ran it in my Q1... I TQ'd.
Adrian Martinez
Old 07-26-2005, 04:51 AM   #24
belgianchamp's Avatar
Send a message via MSN to belgianchamp
Helo,
I'm driving with Reedy QM 19 and can somebody tell me a good setup for the motor?
Springs now i goth orion 135°on the - and orion 150°on the +
Brushes 767 with al hole in 1.5mm
Timing original 24° (is there a better timing for that motor?)
I use comm drops for increasing burning in .
I dont geth really speed in , do i something wrong?On a big track with flowing corners and a straight off +-50m.Gear ratio spur 89 pion 30 and pulley 20( I'm driving with schumacher) and final ratio is 5.34
belgianchamp is offline   Reply With Quote
Old 07-26-2005, 06:09 AM   #25
DIMO's Avatar
Default Agreed
DIMO is offline   Reply With Quote
Old 07-26-2005, 06:09 AM   #26
DIMO's Avatar
Default Agreed
Originally Posted by BlackKat
Adrian: I'm a guy who doesn't touch his Reedy Quad-Mag for 18 runs.....LOL
XXX Brushes are made for people like me
Same Here, But a little Bit expensive at $18AUD a pair
Old 07-26-2005, 08:01 AM   #27
AdrianM's Avatar
Originally Posted by belgianchamp
Helo,
I don't geth really speed in , do i something wrong?On a big track with flowing corners and a straight off +-50m.Gear ratio spur 89 pion 30 and pulley 20( I'm driving with schumacher) and final ratio is 5.34
You have the right brushes but you need stiffer springs. I use Paradigm black Xtra heavy springs. This is stiffer than a Trinity purple. I have used a Trinity purple springs bent to 180 deg + 10 more deg.
If you run Orion springs try the 175deg bent to 180 on both sides:
41328 Pro Laydown Motor Spring 175° / 14oz.
Once you get the stiffer springs do some more gear ratio testing and look at your lap times. Go down 2 teeth from 5.34...one tooth per practice run on the clock and note the lap times then go up 2 teeth from 5.34 one tooth per practice run on the clock and note the lap times. An Orion Pro LCS really helps with this.
A couple of guys PM'd me for dyno readings...I never use a dyno as we never race dynos...lol! Nothing tells you more about a motors performance than a practice run on the clock.
Adrian Martinez
Old 07-26-2005, 09:12 AM   #28
Thx AdrianM,
I live in belgium and in USA the technology is faster than us!!What timing do u prefer to use the Reedy QM 19?Now its standing on 24°.
Old 07-26-2005, 09:40 AM   #29
AdrianM's Avatar
Its illegal for us to change timing so we leave it alone. In the US the motor is locked at 24deg.
Adrian Martinez
Old 07-26-2005, 09:53 AM   #30
OK, in Belgium Nationals you can choose the timing in 19T-class, i now its stupid.
Just wonna fly with my Reedy QM!!!
How to make a hand out motor fast? LosiSuperTruck Electric Off-Road 33 01-26-2006 08:36 PM
how do i make a stock motor fast? fjm9898 Rookie Zone 2 03-27-2005 08:39 PM
Who can make a fast motor!?!?!?!?!? Driver1 Electric On-Road 11 12-02-2004 05:28 AM
How to make your car go fast? Holden Lion Australian Racing 35 02-20-2004 02:01 AM
