3300 or 3700 when running 19t
when running a 19t motor
which would be better
3300 or 3700 ? why
3300 or 3700 ? why
Well . . .depends. If your track adheres closely to ROAR guidelines the 3700's are not legal yet. So in this case the 3300's are the obvious choice. If they are less stringent like my track, the 3700's are the way to go. If you think about a discharge curve of 3700 vs 3300 the 3700 curve is a little longer. This allows you to get your race out of a higher overall average voltage of the 3700 discharge curve than the 3300 curve. Maybe someone else has a better explanation. I am sure you can find more info by searching.
Andrew
Andrew
Andrew
Andrew
