Old 01-24-2014, 02:19 PM   #1
Default My Car is surging (tt01 silver can)
I know that there are many posts on this. (The majority are buried in long posts) However I could not find any answers that apply to my situation.
I have a TT01 running a 540 silver can. I am running the stock esc and gearing 19/61. I am running a nigh battery in the car.
The car runs fine for a few minutes and then loses power and starts back up over and over. If I take the car off of the ground it does not surge.
Any Thoughts????
legacyruss is offline   Reply With Quote
Old 01-24-2014, 03:13 PM   #2
Dread Pirate's Avatar
Trader Rating: 15 (100%+)
Could be a couple things:
1) how hot is the motor and ESC? It could be thermal-ing. Most ESC's have a cut off if the temp is too hot, and will come back on when the system cools down. If this is the case you need to check your drive train for where you are binding up. A silver can at that gear ratio shouldn't be getting hot.
2) weak battery. If it does this within minutes of a full charge then you may not have a good pack. If you have a NiCd or Metal H pack with a bad cell then pack can drop voltage under a load like you discribe.
3) bad ESC. These aren't the best ESC's, I've had problems with the kit ESC, but check the other items before buying a better one.
Welcome to on-road, hope you enjoy it.
"We face each other as God intended. Sportsman-like. No tricks, skill against skill alone." -Fezzik
Dread Pirate is offline   Reply With Quote
Old 01-24-2014, 04:16 PM   #3
Thank you so Much. I will go through this stuff and see if it helps.
