Old 01-22-2014, 02:21 PM   #1
Martin Crisp's Avatar
Default Traction Rolling - how to solve it
Often times when you go to a big race the grip comes up more than your local track and your setup not only does not work, but you traction roll
here are some approaches I have used to help reduce traction rolling
http://www.setupworkbench.com/fighting-traction-roll/
Cheers,
Martin Crisp
Martin Crisp
Power-Story.com | LearnSetup.com
Martin Crisp is offline   Reply With Quote
Old 01-22-2014, 02:27 PM   #2
skater-deez1's Avatar
Trader Rating: 60 (100%+)
Thumbs up
Good stuff,thanks for posting!!!
Going nowhere fast since 1973!
skater-deez1 is offline   Reply With Quote
Old 01-22-2014, 05:09 PM   #3
miller tyme's Avatar
Martin posting again, do I smell a comeback??
Ken Miller
RCTarget - Capricorn - Pro Level RC - MAX Power - Maxima Fuel - EA Motorsorts - TQ Wire
LONG LIVE OPEN MODIFIED
miller tyme is offline   Reply With Quote
Old 01-22-2014, 05:20 PM   #4
How about rear end lack of traction. The rear on my TA06 slides out bad on turn in and a bit coming out of corners
Atechbh is offline   Reply With Quote
Old 01-22-2014, 06:01 PM   #5
You never know!!!
I do miss it.
Martin Crisp
Old 01-22-2014, 06:07 PM   #6
Not knowing what your setup is let me suggest a few things.
Raise the rear roll Center
Add some droop to the front of your car
Lower the front roll Center
Martin Crisp
Old 01-23-2014, 12:17 AM   #7
bkspeedo's Avatar
Martin, There's few things i'm surprised you didn't add to your list.
1. Increase front track width if same as rear, or increase track width front and rear if car is very narrow.
2. Reduce front camber
3. If running regular weight body try light weight
Any reason these would not be good options?
Brent Klingforth
Sponsors: Awesomatix USA ~ Roche USA ~ ORCA ~ AVID Bearings ~ R1 Wurks
TQ Wire ~ Montech ~ WTF ~ BSR Racing Tires ~ 2mm Design ~ Helix Designs
5280 Raceway
MILE HIGH INDOOR CHAMPS April 19-22nd 2018 @ www.milehighindoorchamps.com
bkspeedo is offline   Reply With Quote
Old 01-23-2014, 02:24 AM   #8
VooDooPH's Avatar
Trader Rating: 18 (100%+)
Send a message via Yahoo to VooDooPH
wouldn't reducing front camber aggravate traction rolling? depending on the roll center, the car would have a higher chance of rolling on the outside edge of the outside wheel on corner entry. wouldn't this have a higher chance of tucking the sidewall in and eventually flipping the car?
[TRF418][TB-04Pro][FF-03Pro][M-05v2][TRF102][F-104 WGP][TT-01R TypeE]
[Cross CF-01'08][Yokomo R12][Team C TC02Evo][Team C T8E v3]
VooDooPH is offline   Reply With Quote
Old 01-23-2014, 10:09 AM   #9
Not necessarily. Remember camber is a product in which you generate the widest use of that tire and surface area contacting the surface you race on. If you are 2 deg. Front camber and are utilizing the full width of the tire in a corner that's more corner speed and higher bite. Less camber on same surface will allow the vehicle to grip a bit less and "slip" across the surface a bit more, because you are not using all of your rubber on the surface for grip. The front will push a bit more, and not allow the cars inertia to carry over that outside front tire as much.
Another thing I see as a helper in traction rolling is anti-dive. I've recently started to experiment with this. Helps greatly with augering. Thoughts?
~Xray~RCAmerica~Motiv~Gravity RC~ORCA~Prolevel RC~Team EAM~
Swift Racing Services, LLC.
JDC Motorsports
Boostinswifty38 is offline   Reply With Quote
Old 01-23-2014, 11:05 AM   #10
Reducing camber will help for sure, as will the lighter body. I was trying to focus more on perhaps the less known approaches.
As for the front track width, I would say maybe yes, maybe no. I say maybe no, because if you widen the front track width more than the rear, then the rear tends to roll more than the front, causing the front inside tire to raise up more raising the CG more...leading to traction rolling. I would suggest keeping the track width the same front and rear will lead to better results.
Martin Crisp
Old 01-23-2014, 11:08 AM   #11
yes anti-dive can help as well, but it can also make the car more edgy on turn-in and that abrupt change can sometimes cause the car to hike up before the suspension fully compresses depending on spring rates, shock valving roll centers, track width etc. Having said that, anti-dive is something to for sure experiment with.
Martin Crisp
Old 01-23-2014, 11:17 AM   #12
Default updated the blog post
btw - I added the suggestions above to the blog post
Martin Crisp
Old 01-23-2014, 11:18 AM   #13
Johnn27's Avatar
Trader Rating: 72 (100%+)
Default rear traction
What rear stiffners are you using on the car??? Aluminum or composite ???that might make a big difference also on the ta06...
Johnn27 is offline   Reply With Quote
Old 01-23-2014, 11:21 AM   #14
R3VoLuTiOn's Avatar
Trader Rating: 27 (100%+)
First thing I do on most of my cars is shim out the front / narrow the rear when traction rolling. I guess I should try a different approach! Thanks Martin
When will we finally get to meet you on the West Coast?
John Tsang 🏁 VBC Racing 🚗 ORCA RC 🚗 GripworksRC 🚗 MotivRC 🚗 GravityRC 🚗 RC America
http://www.facebook.com/VancouverRRR 🏁 http://www.facebook.com/OvergearedRacing
R3VoLuTiOn is offline   Reply With Quote
Old 01-23-2014, 11:39 AM   #15
gearhead_22's Avatar
Send a message via AIM to gearhead_22
martin I have your setup workbench on my phone and it is wonderful.
serpent sdx4 srx2 977WC-novarossi-748TQ
serpent S120 LTR-S411
serpent America/Ashford Hobby/skyrocket racing
Juwan Hunter
gearhead_22 is offline   Reply With Quote
