Old 01-26-2014, 07:47 PM   #46
Dynamic weight transfer also includes the effect of roll centers.
The larger the distance between roll center and CG the greater the amount of roll.
frozenpod is offline   Reply With Quote
Old 01-26-2014, 08:07 PM   #47
mikel33's Avatar
Trader Rating: 2 (75%+)
If anyone is interested there is a fairly extensive thread on traction rolling with some very good tips.
http://www.rctech.net/forum/electric...n-rolling.html
Michael Larson.
Village Idiot Racing - Now accepting driver applications.
mikel33 is offline   Reply With Quote
Old 01-26-2014, 08:10 PM   #48
Lessen's Avatar
Send a message via MSN to Lessen
Originally Posted by BadSign View Post
I think it comes down to weight transfer.
Stiffening or softening the car doesn't affect how much weight transfers.
So it would be reasonable to conclude that stiffening or softening the car won't affect traction roll tendencies because those changes "don't affect weight transfer" and that's the key to this issue?
"Nothing in the world can take the place of persistence. Talent will not; nothing is more common than unsuccessful men with talent. "
Lessen is offline   Reply With Quote
Old 01-27-2014, 12:29 PM   #49
Martin Crisp's Avatar
Originally Posted by rc car guy View Post
Um my arms are as low as the can go to the chassis I am running no spacers under my camber links im trying to reduce traction because I lost .2 off a lap and other guys could make changes to take more traction out of their car I cannot as of yet this was for the 3rd and main event its just slow and has too much tracrion in general no traction rolling
Hi
I am having a hard time understanding your posts to be honest sorry.
But I will do my best....
You can have too much traction in the corner in the sense of having too much rear or too much front traction, which affects the balance. However you can't really have too much overall traction in the corners unless of course you are traction rolling.
From your setup info you provided, try adding some spacers to the inboard upper links. This will further lower you roll center, causing the car to roll more and thus loosing lateral grip.
Originally Posted by Stealth_RT View Post
Glad to see you posting again Martin. Love the app! Even use it offroad for escale and etruggy, as long as the track being blown out isn't my biggest concern. (Need an offroad workbench app!)
yeah...certainly all of the information in the app applies to offroad as well. But I don't have anything specific to offroad in the app. I tried offroad a few times and for sure there are things unique to offroad racing that would be good to put into the app.
Originally Posted by rramjet View Post
How weird Martin.
I just posted a recommendation to get your book on another thread today for someone looking for a source of good setup information. Had no idea you were on this site. Also had no idea there was an app. Is there one for us non Apple folks?
lol. There is an android version of the app. But nothing for windows phone or blackberry. Thanks for recommending the app
Cheers.
Martin Crisp
Power-Story.com | LearnSetup.com
Martin Crisp is offline   Reply With Quote
Old 01-27-2014, 12:43 PM   #50
Originally Posted by Lessen View Post
I've been battling this for some time now and could not wrap my head around why so many folks say you must soften the car up. In my head I had always looked at traction rolling as a direct result of too much roll.. limit the roll, limit the tip. Well, it's not that simple I don't think. The physics in carpet racing is very different due to what I might call traction/weight ratio. In the 1:1 world you could stiffen the car up to the point where you limit mechanical grip enough that the outer tires slide because they don't receive enough load. We have so much grip indoors that just doesn't happen, plus the speeds we race at aren't high enough to slide the car (albeit arguably) even if it is set up stiff. I believe there is a correlation between lateral load, vertical load and traction. When grip gets really high we essentially need less mechanical grip to get the car to turn at speed. The problem I think is that in doing so (stiffening the car), we are increasing lateral load and decreasing vertical load on the tire. This is a recipe for even snappier t-rolls. Theoretically, one may be able to stiffen it to the point it is able to break traction, but now you may have a setup that is quite skatey at the limit and just difficult to drive. If you go the other direction and soften the car I think what is happening is that you are effectively decreasing lateral load and increasing vertical loading of the tire (even more mechanical grip). I think it's the balance of this loading that is important here. However, because the car is sprung softly and the roll centers are very low, the chassis has a lot of leverage and less resistance to roll so you still need to limit it otherwise it'll still tip. Now one may be looking at a bit more ARB and things of that nature. Basically, instead of looking for ways to utilize the available traction in an energy efficient manner, we may need to look for way to waste it. By keeping the car softly sprung we are creating more mechanical grip that we actually need, but the direction of the loading may be what we need to keep the car from flipping over.
Setup is a very complicated subject for sure. Here are my thoughts as to why we need to go softer to reduce the traction rolling.
a) If you can lower the CG you will reduce traction rolling
- by going softer and limiting the droop of the car, the car will roll into the carpet more which lowers the CG.
- by reducing droop on the car, the inside will tend not to lift off the ground keeping the CG lower
b) Reducing lateral grip will reduce traction folling
- you can do this in many ways....
-- lowering the roll center will allow the car to roll more, increasing the difference in vertical load between the outside tires and inside tires. My app explains this in more detail but there are formulas that explain that the greater the difference in vertical load between the outside tires and inside tires the less lateral grip you will have.
-- you can reduce the static camber on the tires
-- you can reduce the dynamic camber gain on the tires, by making the upper link as long as possible.
-- you can stiffen the swaybars, which can but not always increase the difference in vertical load on the inside versus outside tires....again leading to less lateral grip. note: I have found in practice however that overly stiff sway bars can make traction rolling worse.
-- glue sidewall...but I don't recommend this unless you have tried everything else
-- etc etc...less gippy tires...etc.
Martin Crisp
Old 01-27-2014, 12:48 PM   #51
yep
I took a look and from my pov, there is a lot of misinformation on that thread.
To help me respond,...when you say stiffening or softening the car...are you referring to the chassis stiffness? the springs? the shock oils? the roll centers?
Martin Crisp
Old 01-27-2014, 01:48 PM   #52
Hi,
Zac sent me an email, but I thought I would post my response here just in case others get value out of it.
1) Roll Center
When you add spacers to the inboard position of the upper links you are lowering the roll centre.
When you raise the inboard position of the lower arms, this raises the roll center.
Another way to remember this is that the less vertical distance there is between the upper link and lower armís inboard pivot points the higher the roll center will be.
lowering the roll centre means the car rolls more and raising the roll centre will decrease roll.
Lower roll centres will cause the car to have less lateral grip.
Higher roll centers will cause the car to have more lateral grip.
2) Droop
Increasing droop will increase the chances of traction roll because the inside portion of the chassis can raise up higher, causing the CG to be higher, than with less droop.
Martin Crisp
Old 01-27-2014, 02:08 PM   #53
Skiddins's Avatar
I think he was sarcastically responding to the post that said stiffening and softening doesn't control weight transfer
Xray T4'18, T4'14 (Wet Car)
Xray X12 2018
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 01-27-2014, 04:30 PM   #54
syndr0me's Avatar
Trader Rating: 32 (100%+)
Two things I've been hearing lately that I haven't seen mentioned here are:
1. use of a front gear diff
2. more drag brake
I haven't tried a front gear diff specifically to reduce traction roll, so I can't comment on its effectiveness, but I can say that more drag brake has been helpful in the past. Obviously both are compromises that may or may not be worth it.
syndr0me is offline   Reply With Quote
Old 01-27-2014, 04:40 PM   #55
hanulec's Avatar
Trader Rating: 27 (100%+)
2. more drag brake
what is this drag brake you speak off.
my favorite is a lighter front bar...
FJ / ROAR #2-122945 / MaxRotation FPV Drone Racing / [email protected] Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 01-27-2014, 04:46 PM   #56
corallyman's Avatar
Trader Rating: 99 (100%+)
Hello Martin,
Nice to see you helping racers out again!
Still have my Windows 8 phone....still love it.....still wishing you'd make an app for it.
Steve
Team ORCA / ORCA USA / Pro Spec
Serpent America / Team Serpent S411 ERYX / On Point Racing OP12C, S120 / Xceed Products
Hangar 30 / Seattle RC Racers
Fasttrax Racing Series / NORA On Road Series
corallyman is offline   Reply With Quote
Old 01-27-2014, 05:19 PM   #57
Lessen's Avatar
He got it!
The link in the OP helped me get a better understanding of what's going on with the tipping. For me it's all about the language and to be quite honest, much of what I read just doesn't make me go "Oh, OK!".
Old 01-27-2014, 08:25 PM   #58
BadSign's Avatar
Trader Rating: 15 (100%+)
I'm saying that if you don't lower your cg, reduce your weight, or widen the track, the only thing that will prevent weight transfer is slowing down for the corner.
But weight transfer and chassis roll are two different things. A stiff suspension will not allow chassis roll, which leads to traction roll. A softer suspension will allow more chassis roll, and therefore reduce the chances of traction roll
Better?
This is the day the Lord has made, I will rejoice and be glad in it- Psalms 118:24
World Champion Turn Marshall
BadSign is offline   Reply With Quote
Old 01-27-2014, 09:35 PM   #59
d'oh
2. more drag brake
Additional drag brake won't really reduce traction roll..it may make it easier for you to slow down enough for a corner.
The front gear diff is an interesting thing. I never really experimented with it to reduce traction rolling. Every time I tried a front gear diff the car felt smoother and easier to drive, but ultimately slower existing a corner because the front wheels are not driving the car forward as much.
Originally Posted by corallyman View Post
Hello Martin,
Steve
Hey Steve. sorry buddy I had a windows phone for a while too. But I was tired of not being able to get the apps I wanted. So back to iPhone again. Hope you are well...Cheers.
Martin Crisp
Old 01-27-2014, 11:01 PM   #60
mikel33's Avatar
Indeed there is. I should have been more specific and pointed to a couple of posts that seemed on point.
Love your app.
Michael Larson.
