Why aren't all 17.5s the same KV?
I'm looking to get into on-road racing, and I was comparing stock motors. It seems like even the same manufacture offers several different 17.5 540 can motors all with different KVs. What's the deal?
Originally Posted by reracer
(Post 12922047)
Kv rating is basically useless. There's no standard whatsoever between companies so there's no standard of measurement.
+1 to the orca 17.5. I'd also recommend a Team Powers Plutonium. |
Different rotor strengths, rotor diameters, air gaps, etc.
Its measured unloaded. Turn the timing up, fit a smaller rotor, and the revs will increase.
Its a useless measurement |
OK, so KV rating is useless for a camparison, can watts be used as a standard measurements?
Bb |
Originally Posted by bucketboy
(Post 12923265)
Bb The cheapest and simplest way for most people to find out if a motor is decent is to ask the people who are winning at the tracks you race at, in the class you race. In reality there's not much between any of the top motors, which is why you see all of them up in the A final at some point or another. If you want a true comparison "number", you'll have to build a dyno and buy/borrow a lot of motors, and even then you end up comparing power curves which isn't always simple. |
Thanks Dale
Bb |
Originally Posted by daleburr
(Post 12923912)
No, as the same issues apply. Crank the timing up and you'll get more peak watts, but at the expense of low-end power and current draw. That's if the watt numbers are even from a dyno and not just invented.
