12th scale set up station?! Can I use my 10th scale station?
Hey guys! I am trying to get my 12th scale driving correctly and I think I need to put it in a set up station. It just isnt consistent enough. I have a 10th scale Integy system for my touring car right now and was wondering if it was possible to make this work for my 12th scale. From what I can see is it's just the front of the 12th scale that goes in the set up station so no need for rear. Do I just need a different size nut for the front axle to fit into the 10th scale station or is it more than that?
Thanks guys!
Kyle
210-722-6891
Thanks guys!
Kyle
210-722-6891
I use my hudy on my 12th scale and it seems to work just fine. I just use 4 front wheel bearings to take up the slack. Basically I put one bearing on with the larger side touching the inside of the setup leg then put another bearing with the large side touching the outside. Then take a small shim and put it on and use the wheel nut to tighten. It seems to work fine until I get my 12th scale.
