Old 01-16-2014, 03:17 PM   #1
DancewithMedusa's Avatar
Default Steering servo help
I'm having some trouble with my steering servo not working.
When I switch the car on, the servo turns right and then realigns (this is normal) and when I trim the steering the servo works fine. but for some reason its not working otherwise. I've tried a new receiver, same thing happened. I don't think its the servo because at times it does still turn.
Help would be much appreciated.
Cheers
DancewithMedusa is offline   Reply With Quote
Old 01-16-2014, 03:36 PM   #2
Jerz616's Avatar
Trader Rating: 49 (100%+)
Cheers
What kind of servo, car, radio/rx. This would help in figuring it out.
Ryan Gracey
XRAY T4'14/ORCA VXX/ORCA TX 5.0
XRAY XB8'14
Jerz616 is offline   Reply With Quote
Old 01-16-2014, 03:51 PM   #3
2xs
Did you properly bind the RX to the TX?
2xs is offline   Reply With Quote
Old 01-16-2014, 03:52 PM   #4
Transmitter is a FS-GT3B and Reciever is FS-GR3C, not sure what brand the servo is. it came with the car and is unlabeled
ARC R10 2013
Tamiya TB-03
Team Titan - Blitz Bodies - Sweep - ARC
https://www.facebook.com/pages/Canterbury-Radio-Control-Car-Club/145070085510599
Old 01-16-2014, 03:54 PM   #5
And yup ive bound it all, it buzzes and sounds like its trying to move but its just doesn't. when I first turn the car on I can move the servo round fine for a couple of seconds then it just jams one way, and every now and then it will actually turn.
I recently bought a new ESC, and instead of having the power to the receiver through the ESC lead it has a separate battery plug. dunno if that'll make a difference?
ARC R10 2013
Tamiya TB-03
Old 01-16-2014, 06:09 PM   #6
IndyRC_Racer's Avatar
Many servos have at least 1 plastic gear in them that can get damaged (stripped gear teeth). This can happen during a crash or if the steering mechanism becomes jammed.
You can do a search on YouTube for rc steering servo repair if you are interested in fixing the servo yourself. If it is a stripped servo gear, you can buy replacement gear sets for most major brands of servos.
Servos can also become damaged by water or too much voltage. This can damage the circuit board and/or motor that controls the servo. Many r/c servo manufacturers offer repair and/or warranty services that may cover a defective servo.
It is always worth checking with the manufacturer of the electronics or kit to see if it is still covered.
Depending on the cost of your current servo, it may be cheaper to just buy a replacement.
I'm currently racing VTA. Check here for rules/info: http://www.usvintagetransam.com/
IndyRC_Racer is offline   Reply With Quote
