Old 01-15-2014, 10:11 PM   #1
rc car guy's Avatar
Default body tuning tips
So ive been searching all over for some sort of information guide to tuning with the body. Specifically tc bodies. Mounting the body forward makes the car have more steering and back less steering, what about the wing? Some wings come with slots to be cut for what purpose, ive only found for an added wing affect, what does that even mean? Also cutting the rear portion after the rear wheel, i heard that it does something, but what, also mounting the wing higher/lower? More rake, on mount the body or less? Mounting the body higher or lower all together?, keeping which portions intact when cutting out the body to increase, or decrease what characteristics? Im sure there are other questions these are the ones i can think of off the top of my head. also i could be wrong on some of the things i said for what does what thats just what im told so far, im trying to figure out the facts
rc car guy is offline   Reply With Quote
Old 01-16-2014, 01:47 AM   #2
Odin544's Avatar
Trader Rating: 93 (100%+)
Read these. http://racepf.com/how-to-tips
Xray - ORCA - Avid RC - MaxFX Paint
TriCitiesRC.com
Odin544 is offline   Reply With Quote
Old 01-16-2014, 05:55 AM   #3
rc car guy's Avatar
Ive read those other than the wing portion it tells you how to paint a body I know how to do that im interestednin tuning with the body
Old 01-16-2014, 08:56 AM   #4
Odin544's Avatar
Sorry thought this was on that page too. Didn't read them as I was posting from my phone. Here is the other one I was wanting to post. http://racepf.com/blog/2013/12/tunin...ear-trim-line/
TriCitiesRC.com
Old 01-16-2014, 09:42 AM   #5
snoopyrc's Avatar
Is this what you read? http://racepf.com/how-to-tips-tcwing Aside from that and the body trim line in the other link I dont know that there is much discussion about aero tuning. I know that oval guys will sometimes intentionally mount it nose left. I think you may be in uncharted territory.
www.battlefieldraceway.com Racing videos at http://www.youtube.com/snoopyrc
snoopyrc is offline   Reply With Quote
Old 01-16-2014, 11:31 AM   #6
rc car guy's Avatar
Ya I caught that on google a yesterday I guess ill have to go mess around with body/wings to see whats what I suppose ... should have a new body painted up tomorrow I butched my other one... the cars dialed so a bit of fine runing with the body/wing should be the little extra I need in the corners
Old 01-16-2014, 06:24 PM   #7
Odin544's Avatar
Protoform sells a set of optional TC wings as well. One high downforce and one normal. Both are higher downforce than the stock wing IMO. They are thicker so they deflect less. They also stand up to abuse better. I thought it was a noticeable difference with no other changes.
TriCitiesRC.com
Old 01-16-2014, 06:35 PM   #8
"■Keep in mind, the smaller the track and lower the speeds, the larger the wing should be" I don't understand this one, you would think with a lower speed the wing should/could be smaller.
outlandr91 is offline   Reply With Quote
Old 01-16-2014, 07:02 PM   #9
Odin544's Avatar
You'd need a larger wing to get the same amount of downforce. Higher air speeds over the wing create more downforce. Going slower would produce less. So if you are going slower you would need more surface area on the wing to make up for the lack of downforce.
TriCitiesRC.com
Old 01-18-2014, 09:07 AM   #10
rc car guy's Avatar
Alright so I did a little bit of testing, not as much as I wanted to, unfortunately the track changed too much from practice on race day to heat #1 and so on. So i was trying to tune on my car rather than work on my body tuning, as a fine tuning option. However I did a small amount of testing with the wings, and wings position. The mazdaspeed 6 body comes with a option cut out for the wing, after destroying my first one in an attempt, I did the 2nd one by hand, I liked how it felt, it was like more down force, and allowed it to rotate around the corners a bit better. I also tried moving the wing to the suggest first hole on the wing, and the suggested one on the body. IT WAS GARBAGE. The car was loose, and rotated WAY too much around every corner. I like the wing at least 10mm of the the end of the car, this also allows the are from the holes I cut into the wing to flow out "smoother" because its not hitting the body before it rolls off of it. Hopefully i can get some practice in on wednesday, and test a few more body tuning options. Oh i forgot i mount my bodies about 15mm past being flush with the front bumper, I have another one that I mounted closer about 10mm past the front bumper, I will probably switched to the one closer to the bumper, when i get my cars traction down a hair more, its skipping around the corner, because my track width is too far apart.
Old 01-18-2014, 02:26 PM   #11
Cadman1981's Avatar
Have you tried moving the body more forward? Gives more turn in grip
Arc R10 2015
Awesomatix A700L
Exotek F1R3
1990s Futaba FXT stadium racer - Mint condition!
And a bunch of other RC kits for me and my kids...yeah...my kids...
Cadman1981 is offline   Reply With Quote
Old 01-18-2014, 02:54 PM   #12
rc car guy's Avatar
Not being snappy or anything but I stated its 15mm beyond the bumper and my other is 10...
Old 01-18-2014, 05:41 PM   #13
Cadman1981's Avatar
Whoops! Sorry
What about putting it at 0mm?
Arc R10 2015
Awesomatix A700L
Exotek F1R3
Old 01-18-2014, 07:43 PM   #14
rc car guy's Avatar
Whoops! Sorry
Less steering
Old 01-18-2014, 08:37 PM   #15
Suspended
Tuning is cool.... Anybody waxing their bodies ????
bertrandsv87 is offline   Reply With Quote
