Old 01-10-2014, 03:26 AM   #1
Default schumacher MI4CXL
Hi guys I have just recently just picked up a mi4cxl its almost brand new now I need a little help the car has a open rear diff and a locked front diff I want it the other way around (no good for drifting) so any help would be great thanks guys
68 cam is offline   Reply With Quote
Old 01-10-2014, 03:57 AM   #2
sosidge's Avatar
Tricky with an Mi4, it's one of the few cars on the market where the front and rear diff are not identical. If you put the spool in the rear the belt pulley will be misaligned, same for putting the diff in the front end, although because the belt is longer you don't notice it so much.
You could try a slight bodge by getting another rear diff for the front and locking the existing rear diff up with glue but I'd be tempted to trade the car for something that is easier to set up for drifting.
Old 01-11-2014, 01:45 PM   #3
so it cant be done or can it be done
Old 01-11-2014, 10:18 PM   #4
The rear diff works ok in the front. You might have to dremel the top deck a bit for belt clearance. If you demand a perfect fit, then an Mi5 gear diff is what you need.
For the rear, the cleanest solution would be the spec-r gear diff for mi4 with the spec-r thing that replaces the gears with a plastic piece that locks the outdrives together. Or just really really thick oil.
Actually, now that I think of it, an Mi5 spool might fit the rear properly, since the mi5 diff fits the front.
-Mike
Old 01-12-2014, 04:32 PM   #5
Thsnks I will look into it
Old 01-12-2014, 04:52 PM   #6
skypilot's Avatar
Trader Rating: 14 (100%+)
if you want a locked rear, why not just lock the diff, lots of way to do it, glue it, cut out pieces of cardboard, (the little header card that staples to the parts package works good) sand paper, tighten the crap out of it.
semi retired..
skypilot is offline   Reply With Quote
Old 02-22-2014, 01:05 AM   #7
obzelite's Avatar
no misalignment on mine, you simply switch diffs, front to rear. flip them left to right and swap the belts left to right.
both belts drive off the same centre gear, so instead of the front belt running down the left side and trying to the run the ball diff that was in the back of the car with the belt at angle, you flip the ball diff and run the belt down the right side. perfectly aligned. same deal for the rear.
TLR 22, XXX-T CR, XXX-SCT, DEX-410, 8ight-e 2.0, axial crawlers.
www.teamadrenaline.net
obzelite is offline   Reply With Quote
