Pro10 - 235mm Electric On-Road Racing
#16
Or build your own chassis, like many of us do in holland ;-)
#17
That's nice! How do you design your chassis? Solidworks? Would it be possible for you to share the files? That's exactly what I wanted for my CRC...
#19
Indeed as standing above there are people also making there own 235mm pancar.
The cars look very nice!
And the entry for the EC is free for all the people.
So put it in your list of races! :-) the more people the better!
I will also join for that race! Just got off from work
Kind regards,
Tim
Kind regards,
Tim
#20
Yodog?
You got the CRC widening kit on it?
If so, no problems with vibration on the rear due to the extensionhubs?.
If you run 10.5 with 1S, go for the 2S boosted setup like spacendeman said.
A lot of fun and you only have to look for 2S battries
If you have the time and money, come to the EC in Germany in march.
Open klasse 235MM pro10 indoor asfalt track.
Entry for every one who want's to join
Regards Roy
Regards Roy
I do use the extensions without too much trouble but as usual I am looking to design a kit to fix this should the need arise. There is a track close to where I live that has a 235mm class and if it continues to grow, I will make some kits.
#21
#23
I have Autocad drawings available for a CRC 235 conversion based on the IRS axle. You can choose stickpack or saddle pack layout.
All you need is 2,5 mm carbon sheets and someone to mill the parts.
Let me know if you want them.
I will post some pictures here.
Cheers
#24
Looks very nice!
Also good to race against it. Very vast car :-)
#27
#28
I also drive an aluminium podplate on my 10SL.
That also reduces the motor temperatiure.
#29
Exactly, carbon fiber is stronger than aluminum but aluminum dissipates heat better than cf. That is why some people use it.
#30
