Old 01-04-2014, 05:55 PM   #1
Default Sanwa M11x Please Help
hi i have been using a sanwa m11x wheel radio for a while now and for some reason it has just started not to centralise the wheel properly,
and into different places and it's not because the spring tention of the wheel is too loose please help
thanks.
aceracer1 is offline   Reply With Quote
Old 01-05-2014, 11:35 AM   #2
NItrox416's Avatar
hi, probably is not a radio issue but a servo one.
Try to put on the car another servo, new should be better, and check if work well with the m11x.
NItrox416 is offline   Reply With Quote
Old 01-05-2014, 02:46 PM   #3
it's not the servo it's the sanwa because it does it when the car is turned off when your looking at the dual rate screen it does not go back to neutral
Old 01-06-2014, 06:19 AM   #4
M7H
M7H's Avatar
Maybe it is time to replace the steering potentiometer, just send it in for service to a service centre.
Serpent
M7H is offline   Reply With Quote
Old 01-06-2014, 07:50 AM   #5
Mr. MR4's Avatar
I have a sanwa exzes x which needs repairs. Where can I get it repaired?
Xray T4'16 HobbyWing Xerun 120A V3.1
Xray X1'16 HobbyWing Justock
Yokomo R12C3 HobbyWing Xerun V3.1
Mr. MR4 is offline   Reply With Quote
Old 01-07-2014, 01:58 AM   #6
Peakki's Avatar
You can calibrate the radio by yourself via VR ADJUST (scroll the menus and you'll find it).
There is instructions in the manual how to do it.
Destiny&V-Dezign 1:12- Sanwa M12s - Xray XB4 2016 - Xray XB2 DE - HW XR10Pro & Team Orion R10.1 Pro & Sanwa Super Vortex Zero Gen2- Team Orion Vortex & Muchmore & Reedy BL motors - Sanwa & Highest & Sav÷x servos
Peakki is offline   Reply With Quote
Old 01-13-2014, 01:49 PM   #7
already done that didn't work
Old 01-13-2014, 02:29 PM   #8
Geezatec's Avatar
How many model you have entered on your M11? One or more models have the same problem?
Default radio by Basic op display Panel, by depressing Inc & Dec at the same time. It'll reset to the original values. Then reset all Exp, EPA, Etc... Also re calibrate your TX to ESC First. For some reason it lost its setting.
Good luck!!
Geezatec is offline   Reply With Quote
