Old 01-04-2014, 05:08 PM   #1
Default Advice on spares to have in stock for xray T4 '14
Hi all,
I am looking for some advice on what spare parts I should have in stock for racing mod with my new T4. Ideally you would have every part in stock of course because happens but what would the bare minimum be? C hubs, belts, steering blocks etc etc. Maybe some pins that get lost?. What would you recommend? Also, if anyone has any must hop ups they can recommend. thanks for the help!
Fly'n Fish is offline   Reply With Quote
Old 01-04-2014, 05:14 PM   #2
Bigz84's Avatar
Trader Rating: 20 (100%+)
Originally Posted by Fly'n Fish View Post
Hi all,
address the front bumper issue, or you will be replacing the chassis because of hard hits.
Airtronics/Sawna : EA Motorsports : Orca : Reflex Racing/RSD : Wild Turbo Fans : RCAmerica : Hudy : Xray : Diggity Designs : Team Scream Racing
Bigz84 is offline   Reply With Quote
Old 01-04-2014, 05:27 PM   #3
thanks for that, yeah i read something about that somewhere I will track that part down too.
Old 01-04-2014, 07:05 PM   #4
Get one from Diggity if you can't find the XRay part in stock.
jjjheimer is offline   Reply With Quote
Old 01-04-2014, 07:35 PM   #5
thanks for that tip!
Old 01-05-2014, 03:08 AM   #6
Sith Lord's Avatar
Trader Rating: 21 (100%+)
Or just make one yourself out of an offcut of CF or Aluminium, like I did
The Xray's are pretty tuff. I had almost one of everything with my old T3. Used nothing! (unless you plan on crashing alot) I'm not buying hardly anything for my T4'14.
Tamiya XV-01 Rally :: Tamiya FAV 2011 :: Proline Pro2 SCB
Sith Lord is offline   Reply With Quote
Old 01-05-2014, 03:30 AM   #7
B00t13g's Avatar
One of each c hub, steering block, rear hub, blades, front composite outdrives(if you run them), complete ecs(as a spare, parts, etc) front and rear belt, inner hinge pins just in case. Only parts I ever really broke were ecs shafts and I wore out blades. The xray is a very durable car requiring very few spares.
Mackenzie Meyercord
Rc America, Xray, MOTIV, Avid, Team EAM, Apex Rc Pro Shop, Pro Spec USA, Sanwa, RSD
B00t13g is offline   Reply With Quote
Old 01-05-2014, 07:30 AM   #8
chasingthepack's Avatar
i have ran mine for 10 meetings now and haven't had to replace anything other than the ecs shafts which i have now removed and im now using the standard shafts
,but im lucky to have a shop at the track every race meeting so i dont carry any spares,i still have my t4 spares so some of those could come in handy,if you have to mail order your spares ,i would have both belts and then one of each part that could get broken in a heavy crash,sometimes on the t4 the top deck can split just behind the motor,but haven't had a problem with the 14
yokomo bd7 16_lrp works team-trinity d4 17.5_futaba 4pks_futaba bls
wet/damp car xray t4-14-r10 pro-team wave 17.5 savox 1251
chasingthepack is offline   Reply With Quote
Old 01-05-2014, 10:02 AM   #9
Hi all,
This is on the xray forum in the same thread as this as a spare list of one of the team drivers seem pretty good and wht I have based my spare on
I use the following option parts:
301213 UPPER GRAPHITE HOLDER FOR BUMPER
302190 GRAPHITE FRONT LOWER ARM PLATE 1.6MM (2)
302169 FRONT SUSPENSION ARM - GRAPHITE - 1-HOLE
303169 REAR SUSPENSION ARM - GRAPHITE - 1-HOLE
303190 GRAPHITE REAR LOWER ARM PLATE 1.6MM (2)
303440 ALU ANTI-ROLL BAR COLLAR (2)
303493 T4 ANTI-ROLL BAR REAR 1.3 MM
305330 ECS DRIVE SHAFT 52MM WITH 2MM PINS
305434 LOW FRICTION KEVLAR DRIVE BELT FRONT 3 x 513 MM
305447 LOW FRICTION KEVLAR DRIVE BELT REAR 3 x 189 MM
306516-O T4 ALU TOP DECK MOUNT - ORANGE
308031-O ALU XRAY SHOCK SPRING RETAINING COLLAR
308264 XRAY 4S SPRING-SET PROGRESSIVE C=2.5-2.8 (2)
308276 XRAY 4S SPRIN G-SET C=2.7 (2)
spare parts which are good to have:
302253 COMPOSITE STEERING BLOCK - HARD - V2
302363 COMPOSITE C-HUB RIGHT - 4 DEG. - MEDIUM
302364 COMPOSITE C-HUB LEFT - 4 DEG. - MEDIUM
305135 COMPOSITE SOLID AXLE DRIVESHAFT ADAPTERS (2)
305241 DRIVE SHAFT REPLACEMENT PLASTIC CAP 3.5 MM (4)
andrewd is offline   Reply With Quote
Old 01-05-2014, 10:59 AM   #10
Don't forget a package of the C-Hub bushings. If you break a steering block the screw and bushing fall out of the bottom, and you might not find it on the track. Be aware the top bushing is a different length then the bottom.
Some people might disagree with me, but I bought aluminum steering blocks for my son's car, as he was breaking 2-3 steering blocks every weekend. The bottom of the block is a weak point. CSO has inexpensive aluminum steering blocks for the Xray cars. Bought those, and have never looked back.
Other then that.. The Xray line of cars are solid. I have TONS of spares that I have never had to use. I am now thinking of buying a new Xray as my T2"s are 8 years old, and just plain wearing out.
Cheers,
Shawn.
Shawn68z is offline   Reply With Quote
Old 01-05-2014, 11:03 AM   #11
Dan
Dan's Avatar
Trader Rating: 48 (100%+)
X-Ray spares are really expensive. I have not carried any suspension spares since racing my T4 in February of 2013. Still on original suspension parts. Really tough car.
I have bought diff gaskets for routine maintenance and wore out a set of stock spool cups, but thats about it.
Dan is offline   Reply With Quote
Old 01-05-2014, 11:39 AM   #12
Sry. Dbl post.
Old 01-05-2014, 07:16 PM   #13
GMartinez's Avatar
Trader Rating: 85 (100%+)
Roll center bushing fellow racer stepped on my car by accident
Only piece that gave was the bushing
www.fullthrottlercraceway.com
Home of The U.S. World Nitro Cup 2013,2014,2015,2016
2014 Roar Electric Nationals, IFMAR ISTC Worlds, 2015 Roar Fuel Nationals
2017 U.S.World Nitro Cup Nov 29th - Dec 3rd
U.S.Open Fuel Championship Returning soon
GMartinez is offline   Reply With Quote
Old 01-05-2014, 11:07 PM   #14
thanks for all the posts guys, I will get the basic spares mentioned and go through the quoted post above for options that are good to have. That was actually something I was thinking about last night, which bits are good to have in the bag for tuning on asphalt. There are a few guys with xrays at the track and I will ask them what tuning parts they are finding handy. Thanks.
Old 01-06-2014, 12:53 AM   #15
Odin544's Avatar
Trader Rating: 93 (100%+)
I've been running Xray for 2 years. Bought a bunch of the various spares thinking it'll be nice to have them if I needed them. Still have every one of those spares new in the package.
You need to consider the tracks you'll be running at. Do they have 2x4 barriers? Are the lanes narrow? I wouldn't get carried away with the spares...
Xray - ORCA - Avid RC - MaxFX Paint
TriCitiesRC.com
Odin544 is offline   Reply With Quote
