Old 01-03-2014, 10:38 PM   #1
theclutch's Avatar
Default Which touring car has the least amount of slop?
I'm contemplating getting another touring car. Which TC, in your opinion, has the least amount of slop in the steering, suspension arms, etc? Ideally, please only respond if you at least have checked out cars for slop. I've noticed, for instance, that off road cars have an incredible amount of slop such that it's probably useless using a setup station for them. If you're like me and suffer from OCD (although I'd argue that it's a positive trait), you would be the type to obsess about cars not having any slop.
So any thoughts and opinions from fellow OCD'ers?
XRAY XB2 2018, XRAY XB4 2017, Durango DEST210R, XRAY XB4 2014, Vaterra Slick Rock, Durango DEX210, SpeedMerchant REV4, HB TCX, Traxxas EMaxx, HPI RS4 Pro, Tamiya TA02, Yokomo YZ10, Associated RC10 Team Car, Bolink Eliminator 10, Kyosho Optima, Tamiya HotShot, Tamiya Grasshopper
theclutch is offline   Reply With Quote
Old 01-03-2014, 11:02 PM   #2
I'm not OCD but by far the most popular car at my club is Xray. I've only compared it to a couple other cars, but I feel like 90% of the people have Xray.(its about 20ish guys in Canada)
lee111m is offline   Reply With Quote
Old 01-03-2014, 11:25 PM   #3
Josh-n-ya's Avatar
Trader Rating: 75 (100%+)
ARC R10! I am still impressed with how tight this car is and Ive been running it for 9 months!
Josh-n-ya is offline   Reply With Quote
Old 01-04-2014, 12:40 AM   #4
xrayracer1's Avatar
Xray Serpent and ARC seem to be the top 3 in no particular order.
xrayracer1 is offline   Reply With Quote
Old 01-04-2014, 02:34 AM   #5
sosidge's Avatar
You are assuming that a lack of slop is a good thing... RC cars seem to need a bit of free play in the components.
I was running the ARC, the tolerances are very fine, the materials are very stiff... and it ran far better after a year of break-in than it did when it was brand new!
Old 01-04-2014, 02:34 AM   #6
whityboy's Avatar
serpent has no slope at all when you bild it, you have to sand most parts for not to bind. but if you run it one month is full of slope
whityboy is offline   Reply With Quote
Old 01-04-2014, 04:53 AM   #7
sashimi999's Avatar
I vote VBC wildfire D06.
::Michael C::
::Speedy RC Racing Blog:: http://speedyrc.blogspot.com.au
::Speedy RC Online Store:: http://www.speedyrc.com.au
::Your Local Dealer for::VBC Racing::BittyDesign::Team Powers::ArrowMax::Blitz Bodies::R1 Wurks::Trinity RC::Team Zombie Batteries::and more...
sashimi999 is offline   Reply With Quote
Old 01-04-2014, 10:03 AM   #8
+1 on VBC
VBC Wildfire D06 - LRP Flow Worx & X20 17.5 Boosted
Xray X12 - LRP Flow Comp & LRP X12 10.5 Blinky
Team Associated SC10FT - LRP Flow & Trinity D3 13.5
Team Associated B4.2FT - LRP Flow & X20 17.5
JQ Products Yellow - Argus A52 .21
Charel is offline   Reply With Quote
Old 01-04-2014, 11:09 AM   #9
Core Creations's Avatar
Trader Rating: 95 (100%+)
Send a message via AIM to Core Creations
Tamiya TL01 is as precise as it gets!!
Core Creations paint thread
Mini Mafia Kansas Chapter - where the monster minis grow!
Core Creations is offline   Reply With Quote
Old 01-04-2014, 12:03 PM   #10
haywood's Avatar
Trader Rating: 49 (100%+)
+1
My Mi5 has plenty of slop but drives quite well. I use to get hung up on slop also but I let it go!
Calandra Racing Concepts/ Hobbywing / Team Scream / Progressive Rc / Ko Propo / MotivRc / Dri-Fit Mafia /
haywood is offline   Reply With Quote
Old 01-04-2014, 12:43 PM   #11
I'm impressed with my xrays. On the 13, you do have to check the arm mounts periodically, and my 14 required a bit of shimming on the hinge pins. Both required some re-snugging of screws in the steering rack after break-in. A bit of ahimming on the axles (particularly the spec-r dcjs) was worthwhile. But after months of use with board taps and stuff, they're still quite tidy. Don't get me wrong, there's a touch of slop, but only what I'd consider appropriate for free movement. Nothing that makes it difficult to get repeatable setup.
My schumacher mi4 lp went together extremely well, bit got sloppy after a bit of running. Then there was the tc6.1...
-Mike
Old 01-04-2014, 12:56 PM   #12
theproffesor's Avatar
Trader Rating: 58 (100%+)
My VBC has very little compared to my Hot Bodies stuff. Also the the VBC comes with shims to take up any slop you may have. I cant compair any other brands. Slop doesn't neccesarily mean bad quality. Could be opposite, if you have to shave and sand every part to fit then its just the opposite asnparts having too much slop. I would actually preffer parts that need a shim verses parts that have to be cut. Nothing like hand fitting spare parts between heats.
The brighter the picture, the darker the negative. USVTA member #112
theproffesor is online now   Reply With Quote
Old 01-04-2014, 04:45 PM   #13
daleburr's Avatar
Xray is the best I've seen and owned, and stays good over time. I've never felt the need to replace any plastic because of slop.
Worst ive seen is the Associated 6.1. Serpent also looks very sloppy.
Keep hearing good things about the Wildfire but sadly not seen one in the uk yet.
Team Xray
RC-Timing Software - http://www.rc-timing.com
Mercedes AMG F1 - http://www.mercedes-amg-f1.com/
daleburr is offline   Reply With Quote
Old 01-04-2014, 04:57 PM   #14
Potoczak's Avatar
Trader Rating: 112 (100%+)
Another vote for VBC d06.
Pete Potoczak
Home entertainment specialist
Secure Technologies/ www.stiworldwide.com
Potoczak is offline   Reply With Quote
Old 01-04-2014, 05:22 PM   #15
Simmi's Avatar
Dream Cars: AWO and TEAM MAGIC
Boulevard Cars: Tamiya Racing Factory ... Kown as TRF 418
Tamiya Racing Factory: TRF 419X
Team Yokomo YZ2 CA
Simmi is offline   Reply With Quote
