Old 01-02-2014, 11:06 AM   #1
jlfx car audio's Avatar
Trader Rating: 36 (100%+)
Default hobbywing 120a 1s in mod tc
I been searching for the hobbywing thread in the onroad section without luck . So here I am till otherwise .
2014 t4
airtronics mt4
fhss4 reciever iI think
hobbywind 120a 1s with fan and heatsink
sonic 5.5
I have it geared at 118/24
Speed is fine punch is fine
drag breaks r issue . Way to strong even at 5%
Im wondering if I have correct software loaded is any better than other ?
I am running a mod profile but it only allows me to run 15deg of boost . Not sure the # of the profile yet
Justin & Matt Lyons
Awesomatix USA, EA motorsports, Sanwa, Protoform, Avid, Gravity Rc , TSR!
a800s sanwa m12s
jlfx car audio is offline   Reply With Quote
Old 01-02-2014, 11:16 AM   #2
oeoeo327's Avatar
Trader Rating: 74 (100%+)
I never used drag brake when using that ESC in a mod TC - didn't seem necessary. The Mod software will allow very limited amounts of boost; if you want to use more, you'd have to load a firmware designed for stock, and be very careful with the amount of boost added by the ESC.
Founding member of the Solid Gold Racing Team - Mediocrity, redefined...
oeoeo327 is offline   Reply With Quote
Old 01-02-2014, 01:07 PM   #3
Trader Rating: 27 (100%+)
The mod firmware for Hobbywing has limits on the amount Of boost/turbo to prevent you from wrecking the ESC when using low turn motors.
Use the stock firmware instead to gain higher boost/turbo capabilities. Also, I always ran 15% drag brake on that ESC, but we have a technical carpet track. I'm not sure what kind you run on.
Xray | Airtronics | R1Wurks LiPo | Hobbywing
hyujmn is offline   Reply With Quote
Old 01-02-2014, 01:16 PM   #4
morgoth's Avatar
I had the same problem a while ago. Recalibrated the esc and everything is fine now. I'm running 14% of drag brake now.
Serpent BeNeLux teamdriver // FX Engines // Nitrolux fuel
My blog: http://scrubbingspeed.wordpress.com
morgoth is offline   Reply With Quote
Old 01-03-2014, 01:06 AM   #5
Suspended
Do you think what brand esc be better?
haha is offline   Reply With Quote
Old 01-03-2014, 05:28 PM   #6
Double post
Justin & Matt Lyons
a800s sanwa m12s
Old 01-03-2014, 05:28 PM   #7
Thanks for the info . But what software gives more fine adjustment on drag brakes? This profile only allows for 5 ,10 ,15........... I have it set to 5 and it still wants to stop on a dime. Other than that im happy with it .
We run at thunder rc in nash and always run the national level race layouts on the 2011 iic rug
Justin & Matt Lyons
a800s sanwa m12s
