Old 01-01-2014, 04:43 AM   #1
Questions?? Tamiya M-05 Stopping
Greetings.
I have a two-year-old Tamiya M-05 kit with a new set of NiMH batteries.
When it ran it went fine, until after a while the car would accelerate, then suddenly stop as it got to higher speeds.
This kept happening, and at increasingly lower speeds it stopped.
So I thought the battery was empty, as it had been running for a while.
Then I charged it. As soon as the battery was full, I ran it again.
After a few metres, the same problem appeared.
Why is this? How can it be solved?
Many thanks,
arvt
arvt is offline   Reply With Quote
Old 01-01-2014, 05:03 AM   #2
Sounds like it could be low voltage protection in the speedo.
You don't say which speedo you're using but if it has a low voltage cut off you can disable it for use with Ni-MH because they aren't as sensitive as Li-Po in that regard.
cyclonetog is offline   Reply With Quote
Old 01-01-2014, 05:13 AM   #3
chasingthepack's Avatar
is it geared correctly,is the esc /motor getting hot ?
yokomo bd7 16_lrp works team-trinity d4 17.5_futaba 4pks_futaba bls
wet/damp car xray t4-14-r10 pro-team wave 17.5 savox 1251
chasingthepack is offline   Reply With Quote
Old 01-01-2014, 05:45 AM   #4
Default Tamiya M-05 Stopping
Thanks for your replies.
Sorry for not being specific. I have very little experience with Tamiya and other kits like these in general.
I believe this is the speedo:
It is made by Tamiya and says this:
"PET SPEED CONTROLLER
EU-104BK"
How do you disable the speedo?
I am not aware of the motor getting hot but didn't have a look last time I ran it. The battery, however, does not even warm up.
Old 01-01-2014, 06:36 AM   #5
sosidge's Avatar
Are you sure the battery is fully charged? NiMH batteries can "false peak" early in the charge cycle, if the battery is still cool when the charge finishes, it isn't charged. What kind of charger are you using? Check the voltage of the pack when it is charged, it should be over 8V.
Check that the car is actually rolling freely when the motor is not installed, if a part is binding up it will cause problems.
I assume you are still using the kit supplied motor. The ESC is not designed to run motors that are much faster.
Old 01-01-2014, 06:50 AM   #6
SuperFastSnail's Avatar
Trader Rating: 79 (100%+)
Default Radio range check
Recheck your battery again, on a full charge it should be higher then 8 volts like what the above post said. You also need to perform a range test of your radio. Have someone hold the car or put it on a stand, walk away from it while you periodically check the range. When your radio is low on battery or if it is having issues send and receiving signals, your car will stall just like what you mentioned.
JU KE
Sponsor by Makita Li-Ion Brushless Power Tools. Eat the power!
Selling something but no pictures, goodbye.
SuperFastSnail is offline   Reply With Quote
Old 01-01-2014, 05:20 PM   #7
Thanks for your reply.
I am pretty sure that it was charged. The charge took a usual amount of time and the charger beeped to indicate it was done. I will however try again and see if that works. The charger can be set to 1, 2 or 4 amps - I used 2 when charging.
Tomorrow I will try and see how the wheels are without the motor. One thing I know is that the problem happens a lot less when the wheels roll freely, without the car being on the ground.
I am using a kit supplied motor. What is an ESC?
Old 01-01-2014, 05:27 PM   #8
OK, thanks a lot. The problem however occurs even when the remote control is right next to the car, so is range an issue? I do not have a voltmeter at home, so testing the voltage cannot be done soon. I will try the other things and get back to you.
Old 01-01-2014, 10:46 PM   #9
Trader Rating: 44 (100%+)
If you have ran i for 2 years straight and haven't done anything to the motor i would say the motor is worn out. Brushes and commutator are probably done. Try a new silver can motor
Justin33 is offline   Reply With Quote
Old 01-02-2014, 01:50 AM   #10
oldnwise's Avatar
Check the connector between the ESC and the battery. If you are still using the standard connector they are known for bad connections and causing the exact problem you describe. Change to a Deans plug.
oldnwise is offline   Reply With Quote
Old 01-02-2014, 03:05 AM   #11
Thanks a lot for all the advice. I will try resetting the speed controller and see if that helps before replacing parts.
Old 01-02-2014, 11:55 PM   #12
Do you have a Castle Sidewinder v2? My brother's v2 ESC was doing that from day 1 and I researched it to be a bad ESC. It ran fine when the car was off of the ground, but once you set it down it became jittery and twitching and would only move forward at half throttle.
I didn't feel like paying the $45 to fix it so it's just sitting around in the house.. I might just sell that dang thing..
Anyway, it could be your ESC.
hkbruin is offline   Reply With Quote
