Old 12-30-2013, 12:45 AM   #1
Send a message via AIM to racer034life
Default which frontend works best in WGT
After looking at other chassis and set-ups i was woundering which frontend works the best. Out of CRC, Associated and speedmerchant old or new school which one works better or the best in wgt. What are some of there pros and cons.
Access Hobbies,CRC, Detc410, Xray T4 15,
The Ian Ruggles Negative Reinforcement Driving School
racer034life is offline   Reply With Quote
Old 12-30-2013, 07:18 AM   #2
big_ads's Avatar
Trader Rating: 80 (100%+)
Send a message via MSN to big_ads
I think the answers you are going to get to this question are going to be a little bit biased. It depends on what each person likes in a car, tough to say which one truly is the "best". Its the old Chevy vs. Ford vs. Dodge argument.
That being said I like being able to adjust the camber on the fly with the CRC front end. Granted they can be a little more time intensive to build but in my experience once you have everything free and functioning properly its the one I prefer to use over all the others.
Adam Balk
Northern Mini Racers (www.facebook.com/groups/northernminiracers/)
Team CRC - Big Head Racing - Dumpers Speed Shop
big_ads is offline   Reply With Quote
Old 12-30-2013, 09:39 AM   #3
Since front ends are no longer interchangeable as they were 20 years ago...the question is pretty much moot. You have to look at the whole car now and decide which you like better. Any of the top brands are competitive.
Old 12-31-2013, 07:49 AM   #4
Will i race with the older crc gen 10 le car and was looking at the speedmerchant new school front end or the associated frontend on a speedmerchant chassis
Old 12-31-2013, 09:57 AM   #5
The Speed Merchant chassis still uses an 8-32 screw to hold the front end on as does the CRC. The new Associated now uses a 3mm screw so it will not work on either of the chassis.
Old 12-31-2013, 10:48 AM   #6
A few oval companies make arm mounts that allow you to use the R5 front end on cars designed for the older front end.
http://www.lefthander-rc.com/catalog...oducts_id=1854
Serzoni is offline   Reply With Quote
Old 12-31-2013, 10:55 AM   #7
Mr RCTech's Avatar
It really doesn't matter which front-end you use it matters how you set it up.
Mr RCTech is offline   Reply With Quote
Old 12-31-2013, 11:13 AM   #8
So why so i see SM wgt chassis or the on-point chassis using the associated frontend's
Old 12-31-2013, 12:03 PM   #9
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Cool
HyperDrive sell front bulkheads for 8-32 hardware
I've tested with AE, and OldSkool
No longer using AE front end, there is a difference, and it's not something you can fix with setup
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 12-31-2013, 12:38 PM   #10
How much of a difference is it? I like the crc frontend cause i like lots of steering. Also i don't see any new school SM frontends out there in WGT. Is there a reason for that?
Old 12-31-2013, 12:50 PM   #11
New Skool hasn't been released yet
High speed stability is the main advantage I saw going away from R5 front end
Old 12-31-2013, 01:11 PM   #12
OkI see so the R5 frontend doesn't like high speeds then? Also what about the SM frontend with the turnbuckles, what happened to that frontend?
Old 12-31-2013, 01:20 PM   #13
R5 front end is very good actually
But on the SM WGT3 I prefer the OS front end, it is very confidence inspiring, especially flat out thru sweepers, side by side with other cars
SM Formula front end, I never tested, but Bruce informed me that it would be similar to R5 feel
Old 12-31-2013, 05:20 PM   #14
SLOWINSLOWOUT's Avatar
Trader Rating: 19 (100%+)
Couldn't help but notice, you are using 16g wire. I take it this is 13.5T Boosted? Do you think 16g wire would be OK with 10.5T blinky?
Also, battery all the way forward with electrics in back, but not all the way. Any advantage to this?
SLOWINSLOWOUT is offline   Reply With Quote
Old 12-31-2013, 05:57 PM   #15
13.5 Blinky US Rules
I'm sure 10.5 would be fine with 16g
