Old 12-31-2013, 07:04 PM   #16
JayBee's Avatar
Trader Rating: 31 (100%+)
Originally Posted by RedBullFiXX View Post
HyperDrive sell front bulkheads for 8-32 hardware
I've tested with AE, and OldSkool
No longer using AE front end, there is a difference, and it's not something you can fix with setup
Is that the AE front end on the car above?
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 12-31-2013, 07:32 PM   #17
That looks like the old school AE lower arms and caster blocks with the R5 upper arms on it.
I am aware that there are aftermarket bulkheads for 8-32 with the R5 front end...for WGT they would be fine. For 1/12th I have heard people having problems getting enough ride height out of them. Just never seemed worth the extra cost to me.
Old 12-31-2013, 07:39 PM   #18
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
All R5 front end bits mounted on
Hyperdrive bulkheads
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 12-31-2013, 07:39 PM   #19
WGT and 12th scale bulkheads are different
No ride height issues for 12th scale
On Point cars use Hyperdrive bulkheads, albeit with 3mm holes
Old 12-31-2013, 08:58 PM   #20
Originally Posted by racer034life View Post
So why so i see SM wgt chassis or the on-point chassis using the associated frontend's
I was using AE R5 front end and the Serpent front end on my On Point 12th. Like the Serpent better, not as twitchy as the AE.
That's R5 front end with V1 lower arm.
I can't find the Hyperdrive R5 front bulkheads for 8-32 screws. Left Hander RC is out of stock and so is RC Hobbies.
RoyU is offline   Reply With Quote
Old 01-01-2014, 08:38 PM   #21
Send a message via AIM to racer034life
I want to compare my crc car to the sm car with the R5 frontend. The. Crc is my first pan car so i want to see what the differences are.
Access Hobbies,CRC, Detc410, Xray T4 15,
The Ian Ruggles Negative Reinforcement Driving School
racer034life is offline   Reply With Quote
Old 01-01-2014, 08:56 PM   #22
I recall some people having ride height issues with them on the 1/12th BMI...most likely on asphalt with higher ride heights.
Old 01-02-2014, 12:49 AM   #23
Pro10noob's Avatar
Using R5 front end with some mods.
B3 kingpins and CRC side springs.
CRC brass balls in lower arms.
This all used on a 235MM Pro10 without any problems in straight running stability and have enough steering.
Using the Onpoint R5 bulkheads tho
Regards Roy
Ps on pic CRC springs are not mounted yet
l===/o\===l
[_]-###-[_] V-link proto type Pro10,JKMR P235-SE Pro10
P235-VL Pro10 comming soon
Sponsered by me,myself and i :)
Pro10noob is offline   Reply With Quote
Old 01-02-2014, 07:26 AM   #24
wingman2's Avatar
The best handling front end I tried on my Corally GT10 car was the old-school Associated front end. I then built up a newer, reactive type front end that mimicked the action of the old-skool front end, but with the benifit of added adjustability.
Old School:
Modded reactive type:
Sponsored by CML Distribution - http://www.cmldistribution.co.uk
wingman2 is offline   Reply With Quote
Old 01-02-2014, 12:43 PM   #25
Will i think it might be time to do some R&D with all the different frontends.
Old 01-02-2014, 02:04 PM   #26
http://www.teamspeedmerchant.com/sho...l/smr1790.html
done
JoelV is offline   Reply With Quote
Old 01-02-2014, 03:50 PM   #27
Pro10noob's Avatar
@JoelV....Indeed oldskool
regards Roy
l===/o\===l
Old 01-02-2014, 07:04 PM   #28
My WGT with prototype New School front end. So far very durable with tons of steering.
team_tamale is offline   Reply With Quote
Old 01-02-2014, 07:14 PM   #29
which frontend works best in WGT-wgt1.jpg   which frontend works best in WGT-wgt2.jpg
Old 03-14-2014, 11:29 PM   #30
I like then new school frontend. Im about to try the long arm frontend on my crc wgt chassis soon.
