Old 12-26-2013, 01:39 AM   #1
ChickenRC's Avatar
Default Need help with receivers and motor fans.
Hi,
i need help plugging a motor fan into a receiver. I don't think it is the right connector to plug into the receiver. I have attached some photo's, might not work, as it is first time. Sorry about one of them being small, they're off google images!
Need help with receivers and motor fans.-esc-fan-photo.jpg   Need help with receivers and motor fans.-picture1.jpg
Got anything against chickens????? If you do, meh I don't care.
ChickenRC is offline   Reply With Quote
Old 12-26-2013, 02:09 AM   #2
daveaustin5's Avatar
Originally Posted by ChickenRC View Post
Hi,
It's not the right connector, that's for a pc.
You can either cut the cables and solder them to the + & - on your esc or you can buy the right connector on eBay and fit it.
daveaustin5 is offline   Reply With Quote
Old 12-26-2013, 03:20 AM   #3
ChickenRC's Avatar
so what is the right connector? and aren't there any adapters?
Old 12-26-2013, 04:04 AM   #4
The right connector looks like this:
I've never seen a converter but it wouldn't be hard to make one. It'd be easier to just fit the right connector though.
Old 12-26-2013, 05:59 AM   #5
chasingthepack's Avatar
as above
yokomo bd7 16_lrp works team-trinity d4 17.5_futaba 4pks_futaba bls
wet/damp car xray t4-14-r10 pro-team wave 17.5 savox 1251
chasingthepack is offline   Reply With Quote
Old 12-26-2013, 07:29 AM   #6
oeoeo327's Avatar
Trader Rating: 74 (100%+)
You could also purchase a fan that's properly terminated and designed for your intended purpose.
http://www.wildturbofan.com/
http://r1wurks.com/product.php?id_product=49
Founding member of the Solid Gold Racing Team - Mediocrity, redefined...
oeoeo327 is offline   Reply With Quote
Old 12-27-2013, 12:52 AM   #7
sashimi999's Avatar
the fan may not be able to provide enough air flow to cool your motor.
It must be designed for esc instead.
Go buy a correct 30mm or 40mm one.
::Michael C::
::Speedy RC Racing Blog:: http://speedyrc.blogspot.com.au
::Speedy RC Online Store:: http://www.speedyrc.com.au
::Your Local Dealer for::VBC Racing::BittyDesign::Team Powers::ArrowMax::Blitz Bodies::R1 Wurks::Trinity RC::Team Zombie Batteries::and more...
sashimi999 is offline   Reply With Quote
Old 12-27-2013, 03:00 AM   #8
ChickenRC's Avatar
I do already have a fan (2.5mm) and the right connector (below) that I removed from an old broken esc. (TEU-101BK (tamiya's stock esc))
How would I solder it when one has 2 wires, and the other has 3? (the connector at the start of the thread that I uploaded has 2 and the one above ^^^ has 3 wires)
Old 12-27-2013, 03:08 AM   #9
ChickenRC's Avatar
sorry 25mm
Old 12-27-2013, 05:27 AM   #10
sashimi999's Avatar
Just solder the black and red wire.
If you need help for the solder job.
Please visit my blog
http://speedyrc.blogspot.com.au/2013...d-fan.html?m=1
::Michael C::
Old 12-27-2013, 07:21 AM   #11
ChickenRC's Avatar
he he i can solder thanks, not a noob
can the yellow wire be cut off completely if I don't solder it? Do I just get rid of it?
Old 12-27-2013, 07:59 AM   #12
There would be no yellow cable! That's just for servos and esc's.
Your fan only has positive and negative so you'd just fit them.
Sashimi's link tells you everything you need to know.
Old 12-28-2013, 01:17 AM   #13
ChickenRC's Avatar
yes but I have an esc connector. If it will work in the same way then I don't want to waste money on another connector. If I cut the yellow cable off, then surely it would work in the same way as just having a positive and negative with no yellow cable ever existing.
What I'm trying to say is, I dont have the right connector, I have an esc connector. Would it work properly if I just removed the yellow cable? If it does work properly (or in the same way as the proper connector), then I see no point in wasting money on the proper connector.
Old 12-28-2013, 01:19 AM   #14
ChickenRC's Avatar
and thanks sashimi, very helpful. especially as I did not know the name of the connector.
