Old 12-25-2013, 01:09 PM   #1
ChickenRC's Avatar
Default L.E.D light system with esc fan?
Hi,
I was wondering if you could plug a 2.5mm esc fan into a G.T power RC car led light system. The plugs are the same, so will it work?
If it won't, can you tell me any alternative ways to run your esc fan, other than plugging it into your esc?
Got anything against chickens????? If you do, meh I don't care.
ChickenRC is offline   Reply With Quote
Old 12-25-2013, 01:25 PM   #2
Odin544's Avatar
Trader Rating: 93 (100%+)
Plug it into the receiver. Depends on the rating of the fan as well. If it can handle 8.4 volts you could wire it direct to the battery.
Xray - ORCA - Avid RC - MaxFX Paint
TriCitiesRC.com
Odin544 is offline   Reply With Quote
Old 12-25-2013, 03:06 PM   #3
ChickenRC's Avatar
is it just a direct fit? will it plug in with no modifications?
